محمد آدم
2024-03-07 22:03
How many kilometers do you guys usually change your brake pads? Yesterday, during maintenance, the technician said the brake pads need to be replaced, but I've only driven 40,000 kilometers. Shouldn't need to change them yet, right?
زايد محمد
زايد محمد2024-11-08 20:53
Brake pads that wear quickly and produce dust are often like this, worn out completely by 50,000 kilometers.
محمد عبدله
محمد عبدله2024-03-09 10:35
Everyone's braking habits are different, just go with what feels right for you. If the brakes need changing, then change them.
Yesterday, I went for maintenance, and they usually use 5W-30 oil. But this time, the technician used 5W-40 oil. I'm not sure if this will have any impact.
Should I replace the brake pads with better ones or go for the original ones? What brands do you guys usually choose?
There's a scraping noise coming from the right front wheel of your 2013 Nissan Sunny, and it's particularly loud when you brake. It sounds like metal scraping. The car has done 150,000 kilometers, and the brake pads are of moderate thickness. The repair shop says there's no need to replace them. What could be the issue?
How many kilometers should the brake pads be replaced on a Smart 453?
Is it necessary to change the transmission oil at 40,000 kilometers?
Hey car enthusiasts, my 2011 manual Alto has done over 70,000 kilometers and needs new front brake pads. Could you recommend a good quality brake pad for me to check out? Thanks!
I've replaced the brake pads and discs on my Mazda6, and also changed the brake fluid, but the brakes still feel very soft and don't stop well. What could be the issue?
Hello everyone! Is it necessary to change brake fluid every 40,000 kilometers? How should I choose brake fluid? Which brand should I choose?
My Taurus just hit 30,000 kilometers. What maintenance does it need? Do I need to change the spark plugs and brake fluid? Thanks, everyone!
Volvo Volvo V40
Volvo V40AED 104,895Petrol
