Hi everyone, I have some questions after test driving a used V40 and need your help! 1. When driving over manhole covers and bumpy roads, the vehicle shakes noticeably, and there's a slight tug on the steering wheel. Is this normal?? 2. When making a slow U-turn, there's a slight delay in power after turning. Is this the normal lag from the transmission? 3. The exhaust pipe on that car is somewhat blackened. Does this indicate oil burning, and if I buy it, how can I fix it??
Hi everyone, I need some advice. I have a 2015 1.4T Touran with nearly 110,000 KM on it. Recently, in the past six months, I've noticed that when making U-turns or reversing into parking spots, there's a sudden large resistance when turning the steering wheel. This doesn't happen during normal driving, only when suddenly turning the steering wheel. Can someone help me figure this out? Thanks!
Hi everyone, I have a 2017 Murano and noticed that the steering wheel doesn't return to the center after turning. Is this normal for you guys? I just discovered this issue.
4Hi everyone, after disassembling and reassembling the intake pipe, the idle is shaking, any idea why? It's an LC100, 4700. I disassembled the intake pipe when replacing the silicone oil fan coupler, and after assembling it, the idle has been shaking. Could it be sabotage?
5After ignition, the hazard lights automatically turn on and can't be turned off, but they disappear after turning off the engine. The hazard lights can be used normally otherwise. What's going on?
6I'm driving a 2022 Hongqi E-HS9 with a range of 690 kilometers. Has anyone updated the system? Is it still lagging after the update?
7I have a 2023 JETOUR X90 Zilong. When driving at low speeds, if I press the accelerator, the car suddenly surges forward. However, after reaching 70 km/h, if I release the accelerator and then try to accelerate again, there's about a 2-second delay before the car suddenly surges forward. Is this throttle response delay a common issue?
8The battery status is normal. What could be the reason for not being able to start the engine after turning it off?
9Is it normal for my steering wheel to make a rustling sound when I turn it more than one full circle during a U-turn or while reversing? I just got my Seetus Luxury Edition 20 days ago.
10After refueling my Jetta VS7 at the gas station, the idle speed tends to be high, around 1000 RPM. Then, during driving, the speed fluctuates. After driving for about ten kilometers, the idle speed returns to normal. Alternatively, if I turn off the engine and restart it, the idle speed also normalizes. I've tested this each time I refuel, and it's always the same situation.
