Help needed, the suspension of my V40 makes squeaky noises when getting in and out or going over speed bumps. I called for advice and they said it might be due to aging bushings. Has anyone else encountered this issue?
Has anyone bought the T8 Pro Sharp Edition? Can the car's internet connection be used? Mine seems just for show. The 4S dealership hasn't activated it, and when I called the manufacturer for help, they said I was complaining about the dealership.
I bought a second-hand Kia Sportage that's 10 years old. When going over bumps or speed bumps, the front chassis makes a creaking noise. I asked a repair shop, and they said it's likely the stabilizer bar bushings have aged. Replacing the two front stabilizer bar bushings would cost over 200, but they also mentioned that changing them might not necessarily solve the problem. Do you think it's necessary to replace them?
4Hello fellow car enthusiasts, has anyone installed coilover suspension on their car? Can it improve the chassis feel? My car is a 2017 4WD Elite with over 90,000 kilometers. When I go over speed bumps or drive on rough roads, the chassis makes a clunking noise. Will installing coilover suspension help?
5Fellow car enthusiasts, my GS5's central control screen keeps rebooting. The 4S shop said the main unit is broken and it would cost 6k to replace it. [Facepalm] Has anyone else encountered the same issue? Is it possible to repair it?
6I bought a second-hand 2013 2.0 Peugeot 3008, and I feel like the rear suspension is really stiff. What can I do about it? Going over speed bumps makes people bounce up. Any advice from experts?
7The repair shop suggested replacing the upper control arm bushing due to aging, but I found online that it might not be necessary. Any fellow car enthusiasts with experience who can help analyze this? The car has 84,000 kilometers on it currently.
8What should I do if the touchscreen stops working? The dealership said it's a common issue, and since it's out of warranty, they suggested I replace it myself (which is quite honest of them). Has anyone else encountered this problem? Which type of screen is suitable to replace it with? 😊
9Is there any owner who has experienced a clunking noise from the chassis when making a U-turn with the steering fully turned? I went to the 4S store, and they said it's a problem with the half axle and needs replacement. Has anyone else encountered this?
10I've got a 2013 Forester and I'm hearing some clunking noises from the chassis. I already replaced the steering rack, but the issue is still there. I'm thinking about changing the shocks next, but the specialist said it's not necessary and that this noise is something the car has had since it was made. Has anyone else experienced this issue? Any advice?
