عبدالرحمن اسماعيل
2023-06-12 02:51
Has anyone experienced idle running at 1000 RPM when the temperature is 35 degrees, and then it returns to normal at 800 RPM when the temperature is 26 degrees? What's going on? Please help.
حسين عبد لطيف
حسين عبد لطيف2023-07-14 11:25
My (vehicle) has consistently maintained 1000 (horsepower).
علي هشام
علي هشام2023-06-12 07:22
Never experienced that. When starting a cold car, after warming it up a bit, the idle speed drops immediately.
Whose car idles at 1000 RPM when warming up, and has anyone fixed it?
What's the idle speed of your Mazda 3 when starting cold? Mine is over 1000 RPM.
T8 idling at 1000 RPM, what's going on?
Why is my S40 idling at 1000 RPM, and how can I bring it down?
It's normal for your NV200 to have a high idle speed of 2000 RPM when you start it cold, and then drop to 800 RPM after about a minute. This process helps the engine warm up. However, if it feels inconvenient, you might want to consult a mechanic to see if any adjustments can be made.
Hey everyone, is it normal for the car's RPM to stay around 1200 even when I release the accelerator while driving? The idle speed is only 800 RPM when parked in neutral. Is it the same for you guys?
Is it normal for the idle speed of a 2015 Volkswagen Touran to rise to 900 RPM when the outside temperature is below 0 degrees while the engine is warm?
When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
It's normal for the idle speed to fluctuate when you turn on the air conditioning in a 2013 1.6 manual fashion model. Sometimes the RPM might go up to around 900 or almost 1000, and other times it might be around 800. If you restart the engine and the RPM goes back to around 800, it's usually not a cause for concern.
Volvo Volvo V40
Volvo V40AED 104,895Petrol
