Do you hear a humming sound on levels 1-3 when you turn on the air conditioner/fan? How can this be fixed?
Comments( 8 )
Is it normal for a loud humming noise, similar to an air conditioner compressor, to come from the front of the car during charging?
When the self-drying function of the unit's air conditioner is activated, will it start after locking the car regardless of whether you turn off the air conditioner before turning off the engine or just turn off the engine and leave the car directly?
4When you start your 2019 model car and turn on the AC for the first time, you hear a noise like the fan suddenly stopping. What's causing this? It only happens once and then works normally afterwards.
5Geely air conditioner only blows on the front windshield, settings don't work, and it fixes itself after a few days. Does anyone else have the same issue?
6After your ASX is turned off, can you hear a clicking sound from the air conditioning vents on the dashboard after about a minute?
7When I turn on the car lights, there's a buzzing sound, like a fan cooling down. Has anyone experienced this? How should I fix it?
8When you hear a clunking sound after turning the steering wheel, what's going on?
9Is there anyone else experiencing a buzzing noise when the air conditioner is on fan mode?
10In March 2021, I had a 2020 model of the Leading Version. A few days ago, while driving on the highway with the AC on, everything was fine for about an hour. Then, it started getting hotter inside the car. When I checked, the air coming out of the AC vent was disappointingly weak. Usually, setting it to level 1 is more than enough to keep things cool, and sometimes I even have to turn it off for a bit. But this time, even when I turned it up to levels 3 or 4, the cold air was still too weak. Finally, I set it to the maximum, which was barely acceptable. At the same time, the noise from the electric fan became increasingly louder. Later, when I turned it back to levels 1 or 2, there was no airflow at all. Has anyone else experienced a similar issue? How should I resolve it? I would appreciate any valuable suggestions. Thank you.
