عبد العزيز دليل
2021-11-04 15:18
Do I need to change the timing belt at nearly 90,000 kilometers?
Comments( 9 )
سلمان ليث
سلمان ليث2023-12-29 13:09
Under normal usage conditions, the oil should be changed at 10,000 kilometers, but you can do it a bit earlier if you prefer.
مدرسي حسين
مدرسي حسين2023-11-12 20:07
I changed it at the end of October, but they messed up the camshaft oil seal, and now there's a bit of oil leakage.
محمد أمين
محمد أمين2023-10-26 22:00
I changed it at 90,000 with slight cracks and aging. I estimate it can last until 120,000 without issue, but since there's no warning before the belt breaks, it's better to replace it early if you're worried.
عبد الغفار عبد العزيز
عبد الغفار عبد العزيز2023-10-24 21:57
It's better to replace it for peace of mind, but the parts are expensive! Check if the tensioner needs to be replaced as well.
سلمان دين
سلمان دين2023-10-04 00:02
Isn't it supposed to be changed every 60,000 kilometers?
حسن له
حسن له2023-03-26 08:17
Check the belt for signs of aging, like cracks or anything similar. If there are any cracks or signs of aging, replace it as soon as possible. If the timing belt breaks while driving, it can be a big problem, potentially requiring engine repair.
سعود سليمان
سعود سليمان2023-03-26 07:59
If there are no issues upon inspection, change it after reaching 100,000 kilometers.
محمد أمينة
محمد أمينة2023-03-25 01:00
Suggest to change.
علي هشام
علي هشام2021-11-05 16:56
The manual seems to say 120,000 kilometers, mine is close to 100,000, so I'm planning to get it changed.
