Can I go to the dealership to have the window seal replaced for free if it's not wiping water properly?
How can I fix the water leakage from the A-pillar seal on the driver's side of my Previa?
Can the rusted car door be replaced for free?
There might be an issue with the seal or a blocked drainage that is causing water to accumulate under the driver's seat. It's best to check for any leaks in the door seals or windows, and also inspect the drainage system to ensure it's not clogged.
4Where can I buy the two water channel seals on the roof of a Volvo S40?
5Can a used X have its battery replaced for free?
6Do you have a link for the window glass inner seal strip?
7Can I go to the dealership to have the window seal replaced for free if it's not wiping water properly?
8I have a new KAMIQ and will be getting the windows tinted in a couple of days. Should I go with the free tinting or pay extra for an upgrade?
9Does the 2021 Murano have a buzzing resonance at 1500 RPM? Should I go to the dealership to request a replacement of the exhaust manifold and bracket? Will not replacing the exhaust manifold cause it to crack?
10I noticed occasional vibrations in my Murano at around 20,000 km, and the vibrations don't last long. When I went to the dealership for maintenance, they mentioned that they could replace the mid-section improvement part with a bracket for free. Has anyone had this replaced? How does it feel after the replacement?
