When the self-drying function of the unit's air conditioner is activated, will it start after locking the car regardless of whether you turn off the air conditioner before turning off the engine or just turn off the engine and leave the car directly?
How to turn off the automatic air conditioning?
Do you hear a humming sound on levels 1-3 when you turn on the air conditioner/fan? How can this be fixed?
4How to turn off the engine sound simulation.
5When the suspension is raised to its highest level, after parking and turning off the engine, the vehicle sometimes lowers to a normal height. I haven't activated the easy entry/exit feature, and it doesn't lower immediately after turning off the engine. Sometimes it doesn't lower at all, while other times it lowers on its own.
6Why can't the cruise control on the LC300 be activated? It shows OFF and won't turn on no matter what I do.
7How can I manually turn off the air conditioning? I always have to tap on the screen to turn it off.
8Does your Santana's engine shake when you turn on the air conditioning for cold air?
9Why does the air conditioning keep turning on and off at idle in first gear?
10If you leave the key in the ignition for too long without starting the car, it won't start. If the key is in the ignition for more than half a minute without turning the engine on, the key becomes stuck and you have to turn off the power and try starting the car again.
