When I lock my car, the key flashes a red light. What's going on? The doors are properly closed too.
Why won't the electric sliding door lock properly? I have to press it with my hand to fully close it.
Why won't the electric sliding door close properly? I have to press it with my hand to get it to lock.
Why is my car key suddenly not responding and unable to lock the doors?
4The FJ keeps showing that the door is not closed. Pressing the lock button makes it beep continuously. Manually locking it works, but it still shows that the door is not closed.
5When you open the door of a Sportage, do the hazard lights flash?
6I recently took my 2021 manual 1.6 35p to the dealership to replace the clutch pedal. After coming back, I noticed that when I lock the car, the indicator lights flash rapidly six or seven times. Previously, they would flash slowly twice. Additionally, there's a warning about low key battery, but the key can still control the car from a distance. What's going on?
7Why do I feel that the soft-closing mechanism on the rear door is less sensitive than the front door? With the same amount of force, the rear door doesn't close properly. Do you guys experience this too?
8Why does the car beep three times when starting, like the sound when a door isn't closed properly?
9I found a problem today, the taillights flashed by themselves. My friend and I were outside the car, the doors were locked, and we were less than two meters behind the car. The key was in my pocket, and the taillights flashed twice on their own, with about a thirty-second interval! What's going on!!! It's different from the hazard lights, it was a quick flash on and off. Is it haunted? 👿👿👿👿👿
10Car enthusiasts, on the 2021 Strength Edition, why does the trunk lock keep flashing even after the doors and trunk are closed? How can I solve this issue? Please let me know if you have any ideas. In my video, the flashing red dot is right at the trunk lock.
