عبدالله بارزاني
عبدالله بارزاني
Nov 2
The driver's side door handle is malfunctioning, and changing the battery didn't help. The passenger side works fine. Do I need to replace the part? It just went out of warranty.
محمد ابيض
محمد ابيض2024-12-01 13:46
My passenger side just went out of warranty, and then I discovered it... [I need some quiet time]
2
عبدالله بارزاني
عبدالله بارزاني2024-11-02 23:27
Door handle malfunction.
After the discontinuation of the X95, what happens to parts and warranty? How do you handle repairs after the warranty period? Are the parts the same as other cars? Is there a design issue?
The passenger side window suddenly won't go up or down, and the driver's side window has broken once before. I can't really vouch for Iveco's quality!
Hi everyone, for the 2019 Hongqi H7, is it possible to move the gear lever button from the passenger side to the driver side?
How to remove the door panel for the driver's side due to noise?
The car battery is dead, how to lock the car doors? Currently, the mechanical key can only lock the driver's door.
After leaving the 2012 Koleos in an open-air parking lot for half a month during heavy rain, the keyless entry on the front doors suddenly stopped working, while the rear doors are fine. Has anyone experienced this situation? Is it a wiring issue or are the keyless entry sensors malfunctioning? PS: It's not a key battery issue.
I found cracks at the connection part of the driver's door on my 2017 Ford Taurus, and there's also one on the passenger side. Fellow owners, is this really a crack?
Can the footwell lights of the RDX for both the driver and passenger sides be adjusted to be brighter?
How to set up the Ariel so that the front passenger or rear passengers can open the door without the driver needing to press the unlock button? Please help!
Changan UNI-T
Changan UNI-TAED 130,000 ~ 152,000Gasoline & Petrol
