حسين انهايان
Dec 1
How do I change the seat memory settings? Every time I get in the car, the seat back reclines. Adjusting and changing the 1, 2, 3 memory positions doesn't work, and I have to adjust the seat every time I get in [facepalm].
Has anyone set up the key recognition feature? After I set up this feature, the seat doesn't return to the position it was in when I last got out of the car. What should I do?
How do I set the seat memory for a 2014 Volvo V40?
I found that the seat memory is gone while driving today. What could be the issue?
4Hey guys, does your car's display screen time often get inaccurate? I have to adjust it every now and then after driving for a while.
5For the 2017 model 95, every time you start the engine, it defaults to automatic mode. Can it be changed to ECO mode?
6Could someone advise how to disable the courtesy seat function on the Aerial? It's really annoying to use every day, and I've checked every setting but can't find where to turn it off.
7How do I adjust the time on the Territory's dashboard?
8Can the rear seats be folded down? Where can I adjust the height of the driver's seat?
9The newly introduced 009 has a comfortable entry and exit feature. However, every time I get into the driver's seat and press the brake, it doesn't restore the previous settings. I have to tap the upper left corner avatar and then select the previously saved driving preferences, which is quite troublesome. Does anyone know how to fix this? Thanks!
10Car enthusiasts, there's a set of test car parts available now: rear seats with electric adjustment and a full set of 14 loudspeakers, plus labor and wiring, all for 1.5. Is it worth it?
