Hi everyone, for the 2023 flagship model with 39,000 km, I've recently noticed that the RPM reaches around 2000 during startup, even when I gently press the accelerator, not aggressively. The car feels sluggish, like it lacks power and accelerates slowly. Have any of you experienced this issue?
Hey guys, my 2017 City is lacking power during acceleration. Can anyone help?
4Hi everyone, I have a 2013 Suzuki Alto automatic. When I start and just slightly press the accelerator, the RPM quickly goes up to 2000. Even when the speed reaches 60, the RPM stays around 2000. What's going on here?
5Does anyone else hear a rattling sound during the start-up acceleration of the 2023 Mini S? What could be the cause?
6I have a 2023 JETOUR X90 Zilong. When driving at low speeds, if I press the accelerator, the car suddenly surges forward. However, after reaching 70 km/h, if I release the accelerator and then try to accelerate again, there's about a 2-second delay before the car suddenly surges forward. Is this throttle response delay a common issue?
7Today, while driving, the engine warning light suddenly came on. No other lights were on, but I felt the engine trembling and it lacked power. After driving for about 150 meters, during idling at a red light, the engine vibration was quite noticeable. When the light turned green and I accelerated, the trembling became more pronounced and it lacked acceleration. I pulled over immediately, waited for about 10 minutes, and after restarting, everything was back to normal. I restarted a few times afterward and everything was fine. The last time I started the car, I drove a few kilometers home and it was normal too. Has anyone experienced this issue? Does anyone know what might be going on?
8As a new driver, I've only driven the 2019 2.0 model, and I find the acceleration quite sluggish. When I press the gas pedal deeply, the engine needs to reach around 1800-2000 RPM to speed up a bit, and the engine noise is quite loud. Is this normal for a naturally aspirated engine with a CVT? I tried using the DS mode, which seems to provide what I consider normal acceleration, but I noticed the RPM goes up to four or five thousand. My friend's 1.5T Geely doesn't make much noise and feels more powerful.
9Help needed, fellow Peugeot owners! Ever since my little Peugeot went on a continuous uphill drive for over an hour a few days ago, it's been having issues. The RPMs go up, but the speed doesn't. It's not too bad when not on the highway, as pressing the accelerator quickly gets the RPMs and speed up. But once I'm on the highway and going over 80-90 km/h, I need to press the gas to at least 2000 RPMs for the speed to increase very slowly. On inclines, if I don't reach 2500 RPMs, the speed drops. I never had to go over 2000 RPMs on the highway before. What's going on? 🌹
10French car enthusiasts, I need your help. My 2.0 engine is making a strange noise. When I accelerate gently, there's no issue, but when I accelerate sharply, there's a "da-da-da" noise at around 2000 RPM. After a few seconds, when the speed picks up, it goes away. There's no noise above 3000 RPM, only during sharp acceleration. I bought it second-hand and didn't notice this sound before. If it's not a big deal, I'll just keep driving it for now. [Yeah][Cute][Cover face]
