My Pang Ge has suddenly started to shake at idle these past two days. Went to the 4S shop and changed the high-pressure fuel pump, checked other areas too. It doesn't shake when driving, doesn't shake when braking with gear engaged, but shakes when in neutral. It shakes as if I'm braking. Can any experts help me figure this out?
Comments( 6 )
When the MINI is in D gear and you brake, if there's a prompt to shift the transmission to P gear, there might be a couple of reasons for this. It could be an issue with the gearbox or a safety feature that's activating. If the car doesn't move when you release the brake, it might be due to a malfunction or an electronic system engaging to prevent movement. It's best to consult the vehicle's manual or contact a professional mechanic to diagnose the issue accurately.
Does anyone else's 2008 occasionally shake when braking?
For the 2017 Middle East version of the 3.6 Grand Cherokee, the central control system is entirely in English. Is it possible to replace it yourself with a Chinese interface that includes CarPlay? Also, in the past couple of years, the fuel pump often stops automatically while refueling, which is likely due to high fuel tank pressure. How can this issue be resolved?
4My Pang Ge has suddenly started to shake at idle these past two days. Went to the 4S shop and changed the high-pressure fuel pump, checked other areas too. It doesn't shake when driving, doesn't shake when braking with gear engaged, but shakes when in neutral. It shakes as if I'm braking. Can any experts help me figure this out?
5Is it normal for the car to shake when downshifting from 3rd to 2nd gear while braking?
6Is it normal for a used 2021 Forester to noticeably shake from side to side when revving in neutral?
7My car is a 2.0 naturally aspirated engine. When I gradually accelerate past 80 km/h, the car shakes a few times, and then it stops shaking. However, if I press the accelerator hard, this doesn't happen. I wonder what's causing this.
8Is it normal for the Haval Jolion Comfort edition to lurch slightly when you park on a slope, shift to P, engage the electronic handbrake, and then release the foot brake?
9When starting the 2014 GS5 2.0 automatic, the car shakes for about 10 seconds. It also shakes slightly when shifting from neutral to drive. Does anyone know the reason? Thanks 🙏🏻
10What is the fuel tank capacity for the 2016 model? I had about 50 km left and when I went to refuel, the pump stopped at just over 40 liters.
