بشير عبدالرحمن
2024-11-29 20:29
My 2023 Yuelin model suddenly has an issue where the dashboard doesn't light up when I open the door, and there's no power on/off music, though the central control screen works fine. What's going on? Sometimes, the dashboard shows a display screen fault, but it resets after restarting. I went to the 4S store for a check-up, but they didn't find any problems.
محمد هاماوي
محمد هاماوي2024-11-30 08:31
I had an unresponsive touchscreen once, but after restarting, it was fine. [I need some quiet time]
20
أحمد مساعد
أحمد مساعد2024-11-30 08:18
It's nothing worth mentioning.
20
Does the 2008 Mazda3 (imported) 1.6L automatic version without a central control screen use a USB drive or CDs for playing music?
I reset the central control screen to factory settings. Now, the keyless entry can only lock but not unlock. How do I set it up? There is power! It seems to be protected. How do I unlock the system?
My 2008 model's central control display screen switches from Bluetooth to the radio, how can I fix it? Also, what is the password for resetting the display screen to factory settings?
Why is there no sound when I connect Bluetooth after modifying the Patrol's central control, even though the music app built into the central control has sound and shows that it's playing? 😢
The dashboard reported low transmission performance, and then the car wouldn't accelerate. After restarting, the warning light went off and it drove normally. What could be the reason? (The onboard computer cleared the fault light, but it came back on before I got home.)
Does anyone experience the 1.3T 80th Anniversary Edition's central control screen occasionally freezing? It gets fixed by disconnecting the power and restarting.
Why is the central control screen in my old Peugeot 308 not lighting up?
Should I replace the 2017 VW Jetta's central control screen at a physical store or buy it online and replace it? Can someone share their thoughts?
While driving, the central control screen suddenly went black, then restarted after two to three minutes, followed by a "pop" sound. Any ideas?
Changan Changan UNI-K
Changan UNI-KAED 138,338 ~ 180,000Gasoline
