حسين وسيم
2024-11-19 10:47
Is the windshield washer fluid that comes with the car antifreeze?
حسين جابر
حسين جابر2024-11-21 23:35
I seriously suspect you're a newbie [Grin]
The washer fluid on my Rapid is spraying too coarse and too low, hitting below the wiper blades. How can I adjust it to spray finer and higher?
The windshield washer spray on the Rapid is too coarse and too low, spraying below the wipers. How can I adjust it to be finer and higher?
Which button on the Ghibli can spray the windshield washer fluid? I've tried the wipers, they work, but I don't know how to spray the fluid. Can any fellow car enthusiasts tell me? Thanks!
I bought my automatic transmission car in July 2017, and it has run 120,000 kilometers. I've replaced the battery twice, a few bulbs, the ABS wire, and the windshield washer reservoir. Now, the front windshield washer isn't working, and the steering wheel feels a bit heavy (very slightly). Regarding the 120,000 kilometers, I want to ask if anyone has experienced changes in steering wheel effort?
BYD Song Plus 2.0 Fuel version, the windshield washer fluid doesn't spray out, but after driving for a while, it starts working again. What could be the problem?
The windshield washer isn't spraying water, even though the tank is full. Does anyone know what's going on? Do I need to go to the 4S shop to fix it?
What could cause the 2014 Peugeot 308 to not spray windshield washer fluid? Is it the lever on the right side of the steering wheel that needs to be lifted forward for a few seconds? I can't find the spray nozzles, so I'm considering using a needle to check if they're clogged. Any advice from the experts?
Peugeot 3008 windscreen washer not working? I've already added three bottles of fluid.
Why does the windshield washer fluid in my 2024 Arrizo 5 run out after just spraying three to five times? I've refilled it three times in a month and used it only about 10 times in total, each time just 1-2 sprays. Could the bottle be leaking? 😂😂😂
Changan Changan UNI-K
Changan UNI-KAED 138,338 ~ 180,000Gasoline
