Hi everyone, I've been looking at the Unik for a while now. Is the shifting smooth or does it have noticeable jerks? I'm about to make a purchase.
Hi everyone, could you please help me with how to use the projection feature on the 2019 flagship MPV? I've been trying for a while but can't seem to make it work. Also, the car system doesn't have a built-in navigation system.
I have a new 2022 2.8 diesel GR version. When the car is cold, there's a noticeable jerk when shifting into reverse. After driving for a while, this symptom disappears. Do you know what might be causing this?
Hello everyone, is it normal for my 2013 Mazda 5 automatic to have a noticeable jerk when shifting from first to second gear, while other gears aren't as obvious?
4Hey everyone, I've been experiencing some jerking when I press the clutch on my car. What could be the reason for this? It happens when I try to shift gears at 2000 RPM.
5Hi everyone, when I'm accelerating with my FJ and shifting gears, I notice that the shift from 4th to 5th gear feels more pronounced and abrupt. Is this normal? There are no error codes. It's not noticeable during normal driving, but if I deliberately pay attention to each gear shift, I can feel a slight jolt from 4th to 5th. To notice this, I have to keep the throttle steady without releasing or pressing it more. During the 4th to 5th shift, there's a noticeable abrupt feeling. However, if I ease off the throttle during the 4th to 5th shift, there's no issue at all. Any thoughts or suggestions are welcome. Thanks!
6What should I do about the gear shifting impact in the Yuexiang when it's fine when cold but jerks when hot?
7Hi everyone, I'm thinking about replacing the center console in my Xiaozhi. Any recommendations?
8Hey everyone, I've been keeping an eye on the Defender for a while now. Why is it that the 828 isn't available in many places? It seems like the 828 and 878 are pretty much the same.
9Does your Jetta automatic also have a noticeable jerk when shifting gears?
10I recently got a CX-5 less than a month ago, and I noticed that when starting the car cold and shifting to D gear, there's a noticeable "jerking" sensation as the car moves forward. After driving for a while and the car warms up, when switching between N and D gear, the jerking sensation is still there but much less noticeable. Is this normal?
