avatar-image
حسين لهب
Dec 12
The clutch of my 2018 Foton Tunland E5 was recently replaced, but there's always a burning smell while driving. Additionally, there's a strange noise when I'm not pressing the clutch, which disappears when I do press it. What could be the cause of this?
نايف سعد
نايف سعد2022-03-06 21:35
New things always need a little getting used to. Usually, after using them for a while, there aren't any issues.
عبد العزيز عبد الغفار
عبد العزيز عبد الغفار2022-02-18 20:51
The three major components are not from the original manufacturer, and even if you replace them with original ones, some may still produce abnormal noise! When newly replaced, there's initially a burnt smell, but it goes away after some time.
Foton Tunland E7, a car from September 2020, has been driven for over 10,000 kilometers. The gear grinding issue when shifting into reverse is very serious. Can any expert provide some guidance?
When driving the 2014 Foton Tunland 2.8S 4WD, there is a noticeable humming vibration in the cabin when the alternator speed is below 1600 RPM. However, once the engine speed reaches 2000 RPM, the humming sound disappears. Could any experts advise on what might be causing this issue?
Why is the clutch on my Foton Tunland E5 so heavy? Fellow car enthusiasts, does your car have the same issue?
Is it normal for the clutch of a 2009 Accent to have some play at the beginning when you press it?
There's a strange smell when using the heater with the recirculation mode in winter.
When I press the clutch, there's a squeaking noise, but it goes away when I release it. Is there a problem?
MG3 2013 model 1.3L manual. Around July last year, the clutch wouldn't spring back, so I replaced the clutch kit. Recently, with the hot weather, the issue has reappeared several times. When the car heats up, the clutch rebound is particularly slow, and after a while, it won't rebound at all. If I park by the roadside for a bit, it gets slightly better. There's also a strange noise when pressing the clutch.
What could be the issue if my manual Jetta's transmission makes a rumbling noise, but the sound disappears when I press the clutch?
