Terralord E3 2.8T Extended Comfort Version 2-cylinder glow plug circuit open fault causes the check engine light to come on. Replaced with a new set of glow plugs, but it didn’t help. How to solve this? Has anyone experienced similar issues? Looking for some advice.
My 2011 Comfort version has the AC on all the time, usually set around 26°C! The fuel consumption is around 10 liters. I hardly use the sport mode. Is there any way to reduce it to the 7-8 liters you guys mentioned? (I'm planning to change the engine oil to 30, as well as the transmission oil and spark plugs soon.)
4Is it necessary to replace the sensor if there's an oxygen sensor 2 circuit fault?
5How to connect Bluetooth on Jeep Compass, step-by-step: 1. Turn on the Jeep Compass and ensure that your Bluetooth device is also turned on and discoverable. 2. On the vehicle's infotainment system, navigate to the Bluetooth settings menu. This is usually found under "Settings" or "Phone" options. 3. Select "Add Device" or "Pair New Device" from the Bluetooth menu. 4. On your Bluetooth device (like a smartphone), go to the Bluetooth settings and search for new devices. 5. When you see "Jeep Compass" or a similar name appear in the list of available devices, select it to initiate the pairing process. 6. A confirmation code might appear on both the infotainment screen and your device. Ensure the codes match and confirm the pairing on both the vehicle and your device. 7. Once paired, your device should connect automatically whenever you start the vehicle in the future, as long as Bluetooth is enabled on your device. If you encounter issues, make sure both the vehicle and device have the latest software updates, and try restarting both if necessary.
6The engine fault code flashes at idle and stays on when starting. The fault indicates a misfire in cylinder two. After replacing the ignition coil and spark plugs, and cleaning the injectors, the fault code disappeared but returned after two days. Do you know what might be causing this?
7There could be several reasons why the music USB drive isn't responding when plugged into the USB port of your car or other device: 1. **Compatibility Issues**: Some car USB ports or devices may have compatibility issues with certain USB drives or file formats. Ensure the music files are in a supported format like MP3. 2. **File System Format**: Check if the USB drive is formatted in a compatible file system, such as FAT32 or exFAT, which are commonly supported by car audio systems. 3. **USB Port Problem**: The USB port itself might be faulty. Try plugging the USB drive into a different port if available. 4. **USB Drive Issue**: Although it works on your computer, there might be an issue with the USB drive that affects its performance in other devices. Consider testing with another USB drive. 5. **Device Settings**: Check the settings of the device you're plugging the USB into. Some settings might need to be adjusted to read external USB storage. 6. **Power Supply**: Ensure that the device has enough power supply to read the USB drive, especially if it's an older model or if there are multiple devices connected. Try troubleshooting with these suggestions to identify the cause of the problem.
8Guys, can you help me figure out what I need to replace here? It's giving me a headache!!! "Jeep Liberty reports C121C Torque Request Signal Denied, first issue." "Crankshaft/Camshaft Timing Misalignment - Bank 1 Sensor 1 - Powertrain Control Module (PCM) fault code: P0016, this is the second issue." "Camshaft Position Sensor Circuit - Bank 1 Sensor 2 - Powertrain Control Module (PCM) fault code: P0365, this is the third issue." "Camshaft Position Sensor Intermittent - Bank 1 Sensor 2 - Powertrain Control Module (PCM) fault code: P0369." "Bank 1 Camshaft 2 Position Slow Response - Powertrain Control Module (PCM) fault code: P000B." "Torque Request Signal Denied - Anti-lock Braking System (ABS) fault code: C121C."
9Don't rush to buy this car just yet; wait for three to four months as a new model will be released. The 2025 model will come out early next year. People are interested in this car mainly because of its zero fire risk and sincere configuration. Be prepared for the following if you decide to purchase this car: 1. The overall electricity consumption is over 20, and it might be even higher for men driving it, considering the car weighs 2 tons. 2. The car has severe nose diving when you brake, causing it to wobble a few times. 3. The sound insulation is poor; you need to close the doors with force, and dust easily gets inside the car. 4. Repair parts are as expensive as those for Mercedes-Benz and BMW. 5. The seats, while known as "Nissan Big Sofas," are not as comfortable as those in the Sylphy. 6. There are quite a few minor issues and faults, with the car's system being a significant drawback.
10In March 2021, I had a 2020 model of the Leading Version. A few days ago, while driving on the highway with the AC on, everything was fine for about an hour. Then, it started getting hotter inside the car. When I checked, the air coming out of the AC vent was disappointingly weak. Usually, setting it to level 1 is more than enough to keep things cool, and sometimes I even have to turn it off for a bit. But this time, even when I turned it up to levels 3 or 4, the cold air was still too weak. Finally, I set it to the maximum, which was barely acceptable. At the same time, the noise from the electric fan became increasingly louder. Later, when I turned it back to levels 1 or 2, there was no airflow at all. Has anyone else experienced a similar issue? How should I resolve it? I would appreciate any valuable suggestions. Thank you.
