فهد حافظ
2021-07-10 07:39
Foton Tunland E7, a car from September 2020, has been driven for over 10,000 kilometers. The gear grinding issue when shifting into reverse is very serious. Can any expert provide some guidance?
فهد لطيف
فهد لطيف2021-08-30 15:02
Grinding when shifting into reverse! Make sure your car is completely stopped before engaging reverse gear to avoid grinding. Or, after stopping, shift into first gear before going into reverse, that should help!
حسن يعقوب
حسن يعقوب2021-07-13 09:55
It's actually good that this crappy car only grinds in reverse! Mine grinds in both first and second gears! The service center can't fix the high water temperature issue! The car lacks power! It's frustrating! Frustrating! Frustrating!
How many airbags does the Foton Tunland E7 have?
What is the factory reset password for the navigation system of Foton Tunland E7 pickup truck? Thanks, everyone.
My Haval HS has been driven for over 12,000 kilometers. Today, after going out and just returning home, the engine emission fault appeared. When I put it in reverse gear, there's no response, but it drives in D gear. Is this issue serious? I'll go to the 4S shop for a checkup tomorrow!
Taurus chassis noise I have a 2019 Taurus, bought in 2021, and it's now at 57,000 kilometers. Recently, there's been a serious noise coming from the chassis, and it gets worse as the weather gets hotter. When the vehicle goes over speed bumps or when the front wheels hit uneven road surfaces at different times, there's a squeaky sound from underneath, like metal rotating inside a rubber bushing. When entering the garage and turning the steering wheel left, there's a clunk noise from the front when the front wheels hit a speed bump. The same clunk noise happens when parking with the steering wheel fully turned while reversing. The noise is very uncomfortable. Any suggestions from fellow car enthusiasts? Has anyone else experienced this?
On the day of the Mid-Autumn Festival, the reverse camera and 360 stopped working. I went to the 4S shop the next day for recalibration to fix it. Because the steering wheel was vibrating while driving on the highway, I did a wheel balancing and four-wheel alignment. Today, while driving on the highway, I noticed that the speed range at which the steering wheel vibrates has expanded, and now the seat also vibrates above 124 km/h. Can any expert provide some guidance?
