Foton Tunland E3 pickup's ABS light came on at 5,000 kilometers, and it was diagnosed that the right front wheel sensor is faulty. Why is it not durable?
Can the rear seats of the Foton Tunland pickup truck be folded down?
How do you fold down the rear seats of the Foton Tunland E3?
4What is the factory reset password for the navigation system of Foton Tunland E7 pickup truck? Thanks, everyone.
5Possible reasons for the acceleration issue with your 2014 2.5 4WD Renault Koleos could include: 1. Engine issues such as clogged fuel injectors or a dirty air filter. 2. Transmission problems affecting power delivery. 3. Faulty sensors like the mass airflow sensor or oxygen sensor. 4. Exhaust system blockage. 5. Fuel system issues impacting fuel economy and power. It's recommended to have a professional mechanic diagnose the problem for an accurate solution.
6The check engine light on my Nissan Sunny came on, showing fault code P0705-00, which indicates an issue with the transmission range sensor A. The car suddenly jerked, and then the gear indicator on the dashboard disappeared. After turning off the engine and restarting, the gear indicator reappeared, but after a while, the check engine light came on again. I went to a repair shop to clear the fault code, and it seemed fine while driving, but the issue occurred again after some time. This has happened several times. Could it be a problem with the right tail light base?
7I have a 2018 Haval H2 manual with a red badge. The ABS light is on, the central console reports an auto hold fault, a hill descent fault, and the steering wheel feels heavy as if it's lost power assist. Previously, a repair shop read the fault codes and showed a right rear wheel ABS fault. I replaced both rear wheel ABS sensors, but the issue persists, and now there's a new problem. Before, I could turn off the engine by pressing the start button once. Now, it doesn't turn off with one press; I have to press the brake and long-press the start button to force it to shut down. Does anyone know what's going on? I'm really fed up with this car. After this experience, I don't want to buy a GWM car again.
