حموي سلمان
2022-08-14 00:05
Foton Cummins engine, 2.8T engine having diesel entering inside, causing the oil dipstick to rise by two to three centimeters every few hundred kilometers. The high-pressure fuel pump has been replaced, and the injectors have been calibrated without any issues.
How is the performance of the Foton E7 with a 2.0T diesel engine?
How does the 2.8T diesel engine of the T60 pickup compare to engines from other brands?
I've got a 2012 Changhe Liana, and it's been having issues with shaking at idle, while driving, and even more when the AC is on. I've already replaced the spark plugs and ignition coils, and cleaned the fuel injectors and throttle body, but the problem persists. The check engine light comes on frequently. Does anyone know what might be causing this issue?
My 2.8t diesel has been driven for three years and 94,000 kilometers. The fuel consumption is still high. Does anyone have a good solution? The current display shows 10.4. With 500 RMB worth of fuel, the range display shows 550 kilometers. The fuel price here is 6.83 RMB.
I've been driving the T8PRO diesel 4WD for less than half a year, and it's been having engine emission issues all the time! I have to go to the service center at least once a week for diagnostics. I'm wondering if this problem can't be permanently fixed...
Has anyone experienced starting issues with their car? This problem has been going on for over a year. I've replaced the battery, cleaned the fuel lines, changed the spark plugs, and replaced the fuel pump, but still can't find the issue. The dealership is also at a loss. Every time I try to start the car, it takes three attempts to get it running. It feels like the fuel isn't reaching the engine when starting. I'm now afraid to drive, because if the engine stalls, it'll take three attempts to start it again. 😢😢😢 Does anyone know the reason?
I just got a 2013 model with a 1.4t engine, and it's been driven for 130,000 kilometers. When I use lower-grade fuel, the high-pressure fuel pump makes a buzzing sound. What could be the reason for this, experts? The sound goes away after driving for a while, but it happens right after starting the car.
The engine malfunction light on my 2010 City recently started flashing. Diagnostic code 14 indicates irregular misfires. I've replaced the spark plugs, ignition coils, and cleaned the fuel injectors, but the issue still occurs intermittently. Every time the light flashes, I restart the engine and the issue disappears for a while before reappearing. Any knowledgeable experts or fellow car enthusiasts have any advice on how to handle this issue?
What brand is the 2.8T diesel engine in the 2015 Wrangler, and is it durable?
