ياسر حسن
2024-06-04 09:42
Does anyone know how to remove the rear door panel of the Explorer E5? How many screws are there? I can't seem to get it off and I'm afraid to pull too hard 😂
I'm looking to replace the gear shift boot. How do you remove the gear shift knob? Has anyone done it before? Customer service said to pull it hard, but I've tried with all my strength and it won't come off. Is there an easier way?
Does anyone know how to remove the door panel of a GAC car? I want to upgrade the door loudspeakers.
How to remove the door panel of MG GT?
The license plate screws are too big. How do you guys handle this?
My car is automatic, and I recently noticed that when I start on an uphill, there's a kind of "bo bo" sound when I press the gas. It seems like it's coming from the transmission. But when I'm driving normally, there's no problem. Even when I hit the gas hard or drive on the highway, it's fine. It's just when I start on an uphill. 😂
How to remove the door panel for the driver's side due to noise?
To replace the dust cover on the gear lever of a 2018 manual transmission ZS, follow these general steps: 1. **Remove the Gear Knob:** First, unscrew or pull off the gear knob, depending on its attachment method. 2. **Detach the Dust Cover:** Carefully pry off the trim panel around the gear lever to access the dust cover. This might require a trim removal tool to avoid damaging the panel. 3. **Remove the Old Dust Cover:** Once the trim is removed, you'll see how the dust cover is attached. It might be clipped or screwed in place. Remove any fasteners and take off the old cover. 4. **Install the New Dust Cover:** Position the new dust cover in place, ensuring it's aligned correctly. Secure it with the clips or screws you removed earlier. 5. **Reattach Trim Panel:** Pop or screw the trim panel back into place around the gear lever. 6. **Reattach Gear Knob:** Finally, screw or push the gear knob back onto the lever. Note: These steps are a general guide. It's always best to refer to the vehicle's manual or consult a professional for specific instructions related to your car model.
When connecting Cyrus to Baidu CarLife, the navigation voice is too low, and the radio volume is too loud, making it hard to hear. How can I increase the navigation volume? The volume button doesn't seem to help.
Is it necessary to put a protective film on the black Zeekr 001? Guys, the expensive ones seem not worth it, and I'm worried the cheaper ones might be hard to remove later. How did you guys decide?
