نايف جابر
2020-03-04 13:59
Beiqi Foton Tunland's low beam bulb burned out in less than a week. The voltage is normal, and the wiring is fine. Does anyone know why this might be happening?
زبيدي عبدالرحمن
زبيدي عبدالرحمن2020-03-04 15:04
You should go to the nearest service station and have a look.
عبدالرحمن باهر
عبدالرحمن باهر2020-03-04 14:14
If the headlight bulbs frequently burn out, it’s likely related to the quality of the bulbs, assuming you've already checked the wiring and found no issues. It’s recommended to replace them with higher quality headlight bulbs.
حسين يعقوبي
حسين يعقوبي2020-03-04 14:13
If your low beam headlight bulb burns out, it might be due to poor bulb quality. Try replacing it with a new one to see if it resolves the issue.
The Viano has a power leakage issue. In less than a week, the battery is completely drained, even the remote control for the doors doesn't work. Still can't figure out the cause.
The clutch of my 2018 Foton Tunland E5 was recently replaced, but there's always a burning smell while driving. Additionally, there's a strange noise when I'm not pressing the clutch, which disappears when I do press it. What could be the cause of this?
I've been driving the T8PRO diesel 4WD for less than half a year, and it's been having engine emission issues all the time! I have to go to the service center at least once a week for diagnostics. I'm wondering if this problem can't be permanently fixed...
Hi everyone, I've been having issues with my Hongqi H7 where the side mirrors often don't fold when I lock the car and the seat adjustment occasionally fails too. I noticed these problems tend to occur together. I had the wiring checked and charged the battery, which fixed it for a while, but then it started happening again. I thought it might be the battery losing charge, so I replaced it. It was fine at first, but then the problems came back. The mirrors fold manually without any issues inside the car; it's just when I lock the car that they don't fold, and the seat adjustment also fails!
Hey buddies, does anyone have a rattling noise from the passenger side dashboard? My car is from 2021 and has less than 60,000 km. It happens when I turn on the power, while driving, and sometimes even when it's off. The noise also appears when I turn on the AC and occasionally when using the wipers.
I'm sincerely looking to buy a used Taycan, 2021 model with less than 40,000 km. Preferably in white. Both Shanghai plates and non-local plates are fine. Ideally, the interior should have red and black, with Bose loudspeakers, electric sound system, and display screens. Budget is 500,000 RMB.
