سعود لطيف
سعود لطيف
Nov 23
Is it normal for brakes to feel softer after driving a new car for a while?
نايف عبدله
نايف عبدله2024-11-25 21:12
The brakes on this car are inherently soft, so you need to anticipate in advance.
أحمد عمرو
أحمد عمرو2024-11-23 17:57
Do you feel any changes in the braking performance? If there's no noticeable change compared to before, you can ignore it. But if there is, you should quickly go to the 4S shop for an inspection! When a new car feels like the brakes are getting softer after a while, it's usually because all parts of the braking system are new and haven't yet reached optimal coordination through use. For example, the contact surface between the brake pads and the brake discs becomes more fitted over time with natural wear, and the gaps may become slightly larger than when the car was first driven.
2019 Changan Yuexiang, after normal driving and parking, when trying to start the car again, the brake pedal is hard and the car won't start. What should I do? Urgent!
I feel like the brakes on the McLaren GT are really stiff. Is it possible to modify them later to make them softer? [Facepalm] After being stuck in traffic for half an hour, my right leg is sore. Also, how do you judge the distance on both sides of such a wide car? Every time I drive on narrow roads, I'm terrified of scratching it...
Hey everyone, does anyone know why a car would suddenly brake uncontrollably for a moment while driving normally, and then go back to normal? Any ideas?
Is it normal for the brakes to apply themselves without pressing the accelerator while driving?
Do you hear a clunking noise when you brake or release the brake while driving your car at low speeds?
Sometimes when I wait for the RPM to drop after starting the car, the engine noise is really loud. The sound gets louder or softer depending on how hard I press the accelerator, and the throttle doesn't feel as powerful as it usually does, requiring me to press it deeper. However, most of the time, this doesn't happen. After the RPM drops, the noise is normal.
Is it normal for the car to shake when downshifting from 3rd to 2nd gear while braking?
Hey car enthusiasts, quick question. When I switch from N to D while idling and press the brake, the car jerks a bit. It's a new car, is this normal?
When the car starts normally and the brake pedal becomes hard after driving a certain distance, what could be the reason?
Why does my car suddenly feel heavy while driving? It always feels like the brakes are on, and it won't move unless I press the accelerator hard...
Hyundai Tucson
Hyundai TucsonKWD 6,000 ~ 10,565Gasoline & Petrol
