علي نبراس
2023-01-26 00:51
I want to ask fellow car enthusiasts, for those with dual-clutch transmissions, does your engine shake like a manual car about to stall when you're in a traffic jam?
أحمد عمرو
أحمد عمرو2024-11-18 18:13
I haven't noticed the issue you mentioned. You might want to check it out at the dealership.
نايف قربان
نايف قربان2024-11-18 17:51
The car shakes when starting from a stop, and also shakes when crawling at low speeds.
لهب نايف
لهب نايف2023-01-26 16:29
You might want to check if there's an issue with the spark plugs or the ignition coil. If there's a misfire, the engine will shake, and if it gets worse, it'll start sounding like a tractor.
فهد عرفات
فهد عرفات2023-01-26 09:22
After driving 17,000 kilometers in a year, I don't feel much during traffic jams. The RPM is at 0.6 or 0.7. I've used auto hold and tried neutral, both feel similar. [I want some peace] For long traffic jams, it's recommended to turn off the engine. If you're crawling, try using the manual shift paddles. [Cool]
Hyundai Hyundai Tucson
Hyundai TucsonAED 86,940 ~ 254,900Gasoline
