Has anyone experienced that the media volume doesn't decrease while reversing in the Tucson L recently?
The second key hasn't been used for a while. Recently, I took it out and found that the remote doesn't work. I changed the battery, but it still doesn't work. Does anyone know why?
Has anyone experienced the transmission not shifting while driving the 2.0T model? Thank you.
Is there anyone who has experienced the car cigarette lighter charger not charging the phone when it's not in use, and the battery level actually decreasing instead of increasing?
4The 360-degree panoramic reverse view is not displaying, and sometimes there's a snowy screen. Has anyone else experienced this?
5Is the engine of the 2018 automatic model noisy while driving? Has anyone experienced something similar?
6Has anyone experienced their head-up display flickering while driving?
7Recently, on the highway, my steering wheel was shaking. Has anyone else experienced this?
8Why is the volume on the Jeep Wrangler set to maximum by default? Has anyone else experienced this? How can it be resolved?
9After starting the 2019 Taurus, the steering wheel won't turn in place, even when reversing. It only turns when reversing while moving. However, it works fine when driving forward. Has anyone experienced this issue?
102016 model Touran L's air conditioning starts cooling, but stops after a while. Replaced the solenoid valve and cleaned the control board, it worked for two days and then the issue reoccurred. Has anyone experienced this? How did you solve it?
