سلمان ثاني
سلمان ثاني
Dec 14
Does anyone feel that the steering of the Tucson tends to drift on the highway? I constantly need to make small adjustments. Is there no self-centering, or is there a setting for this? It's quite tiring to drive like this.
عبدالرحمن قادر
عبدالرحمن قادر2024-12-03 00:06
Has it been resolved? I seem to have the same feeling. [I want to be alone]
سعود رأس
سعود رأس2024-12-02 06:23
If you feel something is off, just go get a wheel alignment.
أحمد عمرو
أحمد عمرو2024-12-01 23:43
The electronic power steering is very light, and slight adjustments while driving are normal. Additionally, 1. Road conditions. 2. Tire pressure. If you're concerned, you can have it checked at the shop.
سعود رامز
سعود رامز2024-12-01 18:09
New car with 2000 kilometers, same feeling. Any solutions?
20
علي مكرم
علي مكرم2023-12-14 20:35
The speed is fast, but how long can a truly straight line be? You definitely need to make constant adjustments. Turning on lane-keeping can make it a bit easier.
How to solve the seal problem? Has anyone else encountered this? It drifts to the right quite severely. Kugou can't open. There's a strange smell from the air conditioning. The steering wheel vibrates a lot, and in winter, the range is only 60-65% of what's advertised.
When driving on the highway, wind noise and tire noise are quite loud. How can I deal with this? Does anyone have any advice?
HS 30T 2WD, when driving on the highway, the steering feels sticky and doesn't return to the center, making it tiring to constantly adjust. This doesn't happen at low speeds or in hot weather. Has anyone else experienced this? How did you solve it? Some say it's an issue with the steering gear and needs a full replacement—is this true?
When driving the Song Plus fuel vehicle at high speeds, subtly adjusting the steering feels like the steering wheel is sticky and requires some effort to push. It feels heavy, and I have to constantly correct it without any self-centering rebound force. What's going on?
Does your Song Plus automatically realign the steering when you make small adjustments on the highway? Is there a lot of resistance when you adjust with one hand?
Does your car's steering wheel automatically return to center when you make slight adjustments at high speeds? When you make minor adjustments with one hand, do you feel a lot of resistance?
Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦‍♂️
To turn on the heater without the AC light coming on, you usually need to adjust the settings on your car's climate control system. Make sure that the AC button is turned off. If your car has an automatic climate control system, try switching to manual mode and adjusting the temperature and fan settings manually. If the AC light still comes on when you activate the heater, it might be due to the car's design to dehumidify the air, in which case you may need to consult your vehicle's manual or contact a service center for further assistance.
I recently bought the 2024 Tiida Intelligent Edition and it's my third time driving on the highway. When I reached 130 km/h, I noticed that after exiting the highway, the steering wheel needs to be slightly turned to the right to go straight. If I keep it centered, the car veers to the left. Is this normal? Also, is getting a wheel alignment expensive?
Hyundai Tucson
Hyundai TucsonQAR 74,500 ~ 125,004Gasoline & Petrol
