فهد عائشة
فهد عائشة
Dec 11
2009 Yaris, the cup holder on the passenger side dashboard is making noise, not sure what to do about it. Anyone got any ideas? [Crying][Crying][Crying]
عبدالله نور الله
عبدالله نور الله2023-09-13 13:22
It's better to use a small towel as padding to stop the noise! Give it a try!
حسين يعقوبي
حسين يعقوبي2023-09-08 12:07
Is it fixed? Mine also has a noise coming from the cup holder on the passenger side.
نايف نواف
نايف نواف2022-02-15 23:02
The cup holder works much better when it's closed, it makes a noise when opened. 😊
علي عامر
علي عامر2021-12-13 10:13
Could you check if there's anything inside?
The car makes a lot of noise when driving, not sure why.
Does anyone else have a noise issue with their sunroof? My 2018 car has a serious noise problem at the rear on the passenger side. 🤦‍♂️🤦‍♂️🤦‍♂️
I have a 2009 Toyota Yaris 1.6 automatic. Recently, the car has been making strange noises. It sounds like a spring or shock absorber is out of place. Does anyone know what the issue might be? Is it serious?
Hey everyone, I recently noticed a rustling noise near the B-pillar on the passenger side when driving over bumpy roads. I've had the car for a year, but this just started happening. It doesn't make noise on regular bumpy roads, only when the car sways side to side. I've tried fastening the seatbelt and applying grease to the buckle, but the noise persists. Has anyone else experienced this? Any suggestions on how to fix it?
Hey folks, got a low oil warning and the next day it started making noise. Even after adding 4 liters of oil, it's still the same. Any idea why?
The passenger seatbelt outlet keeps making noise while driving, it's too loud. How can I fix it?
Does the 2017 Santana with a 1.4 engine have a loudspeaker on the passenger side? My passenger side got wet, and I'm not sure if there was a loudspeaker there originally.
Does your SUV make a buzzing noise from the rear passenger side when driving at speeds of 20-30 on bumpy roads? There's no such sound from the driver's side. Without some music, it's really hard to ignore that noise!
I'm planning to replace my 2023 Porsche Panamera 2.9T with a used Ferrari. Not sure if it's a good idea. [Crying]
Toyota GR Yaris
Toyota GR YarisOMR 5,000 ~ 7,849Gasoline & Petrol
