When lightly pressing the brakes on the Vellfire, there's a slight "click" sound. Has anyone else experienced this?
Is there anyone else whose car makes a slight plastic rubbing sound when turning the wheel to the left?
I have a 2018 2.0 4WD Jeep Renegade. When I start the car, while the gear is in the P position and I press the brake, I hear a clicking sound from the gear area. Has anyone else experienced the same issue?
4I have a 2015 manual car, and there is a slight clicking sound when refueling. How can this be addressed?
5Has anyone else encountered this issue? Recently, when I activate the auto hold, after the car stops, the AVH light blinks and then there's a clicking sound. It happens every time. If I press the brake harder, the sound is louder; if I press lightly, the sound is softer.
6Is anyone else experiencing the issue where the air conditioning vent actuator motor is broken and makes a clicking sound when powered on?
7I have a 2017 V60, and sometimes I hear a clicking noise from the chassis when driving at high speeds. The noise disappears if I lightly tap the brakes. I suspect it might be an issue with the brake system, but I've been to the dealership twice and they couldn't solve it. Has anyone experienced a similar problem? Any solutions would be greatly appreciated!
8The turn signal is intermittently malfunctioning. Most of the time, it fails when the headlights are turned on—there's no light or clicking sound. Once the headlights are turned off, it works fine again. Has anyone else experienced the same issue?
9When lightly pressing the accelerator at low speeds, there's a slight jerk, and when the RPM drops below around 1100, there's a dragging feeling. What could be the problem?
10Has anyone experienced a noise from the front right wheel, like a screeching sound, especially when lightly pressing the brakes or driving at 20-30 km/h after braking? The noise is very sharp.
