عبدالله خلف
2022-07-15 13:01
The Vellfire has been driven over 40,000 kilometers, and there's a lot of noise coming from the rear tires. Upon inspection, the inner tires are worn, and both tires are the same. What could be causing this?
Comments( 13 )
علي صدام
علي صدام2022-10-25 10:10
Boss Cai mentioned that Japanese people tend to have an inward toe position from kneeling for long periods, which can be adjusted at a repair shop.
عبدالرحمن زين
عبدالرحمن زين2022-10-06 05:29
This is common, just rotate them with each maintenance.
علي فارس
علي فارس2022-09-30 11:11
Purchasing adjustable rear control arms can solve the problem.
عبدالرحمن شهيد
عبدالرحمن شهيد2022-09-26 18:37
Common issues
رياض حسين
رياض حسين2022-09-08 17:23
This car definitely lives up to its name as a "nanny car." I drive it often, and the rear tires wear out pretty badly after just 10,000 kilometers.
فهد خدي
فهد خدي2022-09-07 20:35
I haven't noticed any tire wear after driving 36,000 km. It's recommended to just get a four-wheel alignment.
علي طب
علي طب2022-08-28 15:59
The same issue, after driving for 35,000 kilometers, this situation has occurred. There's a clunking noise.
عبد العزيز صالح
عبد العزيز صالح2022-08-25 07:59
Just rotate the tires at 5000 kilometers and that's it.
محمد وسيم
محمد وسيم2022-07-30 17:26
Just add a stabilizer bar.
فهد وهاب
فهد وهاب2022-07-27 00:42
I've driven 30,000 kilometers, and there's a loud "clang clang clang" noise from the tires.
The 2014 Jeep Compass with a 2WD CVT transmission is great in many aspects, but I'm worried about the starting issue. If the RPM is too low, the car doesn't move, and if it's too high, it might damage the transmission. [Covering face] I'm concerned that this could cause problems during vehicle inspection. Are there any fellow owners with the same model who can offer some advice? The CVT inspection is really giving me a headache. Fellow car enthusiasts, please share some tips!
I’ll share my personal test drive impressions of various SUVs in the same price range. Can anyone explain the difference in chassis feel between the GV70 Flagship and Luxury models? If there's someone who has driven both, please provide detailed insights! I've also tried SUVs of the same class like BBA, Volvo, and Jaguar. Personally, I think the new GLC has the best overall chassis quality, with Genesis coming in second. Genesis has the best sound insulation! The throttle response is the worst on the GLC! The X3, Q5, Genesis, Volvo, and Jaguar feel quite similar. Subjectively, the GV70 ranks in the top two for overall comfort and drivability. PS: The Q5 feels more filtered and softer. The X3 is a bit too ground-hugging and follows the road surface too much, which I don't like. Volvo is in the middle, but it has the worst sound insulation in its class! The GLC's chassis quality is great with a solid, integrated feel, but the throttle response is really lacking! The Jaguar F-Pace has a slightly firmer chassis and a more sporty driving feel, but its downside is average noise control with some resonance, and it has the smallest rear space. Genesis offers the best overall driving experience. Even with 21-inch wheels, the suspension is really excellent, and the power delivery is smooth and responsive. The space is similar to the X3.
My 2021 model has run about 53,500 kilometers, and both rear tires are almost completely worn out! Which brand of tires are you guys switching to now?
17 Leading Edition... 220,000 km driven. The engine cylinder head is damaged, causing water leakage. Has any other owner encountered the same issue?
The sound of rustling near the throttle belt on a 10-year-old Alto could be due to several reasons. It might be caused by a worn-out or loose belt, debris stuck in the belt area, or possibly an issue with the belt tensioner. It would be best to have it inspected by a professional to determine the exact cause.
2022 HONGQI HS7 QiChang with five seats, driven 8000 miles. After rain, the keyless entry system failed. The key can only lock and unlock the doors; inside the car, the key is not recognized (both keys have this issue), and the car won't start (even emergency start doesn't work). HONGQI Smart Connection can start the vehicle, but it can't be driven away. The 4S shop inspection indicated a key matching fault, and after re-matching, it worked fine. However, the issue reoccurred 5 days later. What could be the problem? Have any fellow car enthusiasts experienced this? How do you deal with it?
Yesterday, I went for the three-year warranty and maintenance. The after-sales service suggested I change my tires, saying the treads are almost worn out. I've driven 56,000 kilometers. How many kilometers did everyone else change their tires at? Has anyone switched to different tires? Continental is really too expensive for me. Are there any high cost-performance alternatives?
Toyota Toyota Vellfire
Toyota VellfireAED 2,200,000Hybrid
