Is there anyone who has experienced the car cigarette lighter charger not charging the phone when it's not in use, and the battery level actually decreasing instead of increasing?
Hey folks, the cigarette lighter below the center console in my Sportage has power, but when I plug in the car charger, there's no response. The charger is good. What's the issue?
For a 2011 Volkswagen Phaeton with 130,000 kilometers, experiencing issues with the key frequently failing to unlock the doors or the car not detecting the key inside, along with a loud engine noise, here's what you can do: 1. **Key Issues:** - **Battery Check:** Start by checking and replacing the battery in your key fob, as a weak battery can cause these problems. - **Signal Interference:** Ensure there is no electronic interference around you when using the key. Sometimes other devices can disrupt the signal. - **Reprogramming:** If the issue persists, consider having the key reprogrammed by a professional. 2. **Engine Noise:** - **Oil Level and Quality:** Check the engine oil level and quality. Low or dirty oil can increase engine noise. - **Regular Maintenance:** Ensure regular maintenance is performed, including oil changes and tune-ups, to keep the engine running smoothly. - **Inspect Components:** Have a mechanic inspect the engine components like the timing belt, exhaust system, and other parts that might contribute to the noise. Regular maintenance and addressing minor issues promptly can help maintain the car's performance and longevity.
How do you charge your phone? The cigarette lighter USB can't charge my iPhone, but it works with OPPO. Does anyone have any solutions?
4Is there anyone who has experienced the car cigarette lighter charger not charging the phone when it's not in use, and the battery level actually decreasing instead of increasing?
5For the 2023 Model X, there are several accessories you can consider to enhance practicality beyond the basic seat covers and floor mats, especially for your 5-seater version. Here are some suggestions: 1. **Trunk Organizer**: Helps keep your trunk tidy and maximizes space usage. 2. **Sunshade**: Protects the interior from heat and UV rays, keeping the cabin cool. 3. **Screen Protector**: Prevents scratches and reduces glare on the touchscreen. 4. **Wireless Phone Charger**: Convenient for charging your phone without cables. 5. **All-Weather Floor Liners**: Offer better protection against dirt and spills. 6. **Roof Rack**: Adds extra storage capacity for trips and outdoor activities. 7. **Console Wraps**: Personalizes the interior and protects from scratches. 8. **Portable Vacuum Cleaner**: Keeps the interior clean, especially useful for families or pets. These accessories can improve the functionality and comfort of your Model X.
6For those who have already picked up the car, could you please share how much the actual range decreases in summer? Mostly driving in urban areas with little highway driving.
7My 2019 Model 95, the USB port next to the cigarette lighter on the center console isn't working. It doesn't charge my phone, and when I plug in a USB drive, there's no response. What's going on?
8If your T99's battery is seriously drained and loses power after just a week of being parked, there are a few steps you could consider: 1. **Check for Parasitic Drain:** Ensure that no electrical components are drawing power when the car is off. This might include lights, the radio, or other electronics. 2. **Battery Health Check:** Have the battery tested to see if it's in good condition. Sometimes, a faulty or old battery may need replacing even if the car has only run 12,300 km. 3. **Alternator Check:** Make sure the alternator is charging the battery properly when the engine is running. 4. **Battery Maintenance:** If the car is parked for long periods, consider disconnecting the battery or using a trickle charger to maintain the charge. 5. **Professional Help:** If the issue persists, it might be a good idea to consult with a professional mechanic to diagnose and resolve the problem. Dealing with battery issues can be frustrating, but these steps might help in identifying and fixing the problem.
9The charging system issue on the 2009 MDX flashes briefly and then disappears. Even after replacing the alternator, the problem persists. While driving, the charge level decreases and then recovers. It's really frustrating, is there any expert out there?
