How to use cruise control?
Can the 1.5L Comfort model be equipped with cruise control? Does the original car system include a cruise control module?
How do I use the cruise control on Haima S5? Can someone please teach me? 😊
How do I use the cruise control on the 2019 Yuxiang?
4How to use cruise control?
5Can the premium version, which only has cruise control, be upgraded to adaptive cruise control?
6Does this car have cruise control?
7What is the maximum speed of the X cruise control?
8The difference between canceling cruise control and turning off cruise control in a Patrol is essentially about how the system is deactivated. Canceling cruise control is a temporary deactivation, allowing you to resume the set speed later, while turning off cruise control completely deactivates the system until you set it up again.
9The difference between the "Cancel Cruise" and "Turn Off Cruise" buttons on the steering wheel of a Patrol is as follows: - **Cancel Cruise**: This button temporarily deactivates the cruise control while keeping the set speed in memory. You can resume the cruise control to the previously set speed later without having to set it again. - **Turn Off Cruise**: This button completely deactivates the cruise control system and clears the set speed from memory. To use cruise control again, you would need to set the speed anew.
10Does the 2023 Macan 2.0T come with standard cruise control or adaptive cruise control? Can someone explain this?
