How to open and close the electric door of a Vellfire without shifting to P gear?
My M7's electric right middle door isn't working. It opens a little, and if I press it again, it opens a bit more, but it won't close completely. Experts, what could be the reason for this?
4The side electric sliding door of the Multivan can open, but it doesn't respond when closing. What could be the reason?
5After replacing the battery in the Sharan, the electric door won't open. Looking for a way to reprogram it.
6Guys, I'm really freaking out. Just now, while driving smoothly, the D gear light (the one on the gear shift) started flashing, and the dashboard showed "Please shift to D gear first before selecting the appropriate gear." I was in a panic and didn't know whether to press the brake and shift to P gear or shift to P gear and then to D gear, and then it prompted "Speed too high to shift into D gear (or maybe P gear, I forgot)." It was terrifying, the car felt like it was in neutral and there was no power when I pressed the accelerator. I managed to park on the side using inertia, shifted back to P gear, and then to D gear, and it resumed normal driving. I want to ask you guys, what's going on here exactly? Is there a specific part that's malfunctioning?
7What could be the issue with the electric sliding door of my Volkswagen Sharan not fully opening or closing?
8Anyone knows why the 3008 shows the door is open on the dashboard even though it's closed?
9Is there anyone who knows what's going on with the electric tailgate making a loud and piercing noise when opening and closing?
10Nissan X-Trail e-Power, I have two questions: 1) When the door is opened in D or R gear, the car alarms, but it doesn't shift back to P gear. Is that correct? I seem to remember it would automatically shift back to P gear before. 2) The speed-sensitive setting for the front wipers is on, but it doesn't seem to activate automatically when it rains. Why? Thanks for the explanation.
