Where is the Subaru's particulate filter located, and will short city commutes of 3-5 km cause it to clog easily?
Does the engine of MAHLE Powertrains have a particulate filter?
Just wondering, I really like this car's 8AT and 2.5T. But do you know if it has a particulate filter? And is the engine longitudinal or transverse? Also, how's the sound insulation?
4Does anyone know about the original engine mount for the Jeep Patriot from the US? There are too many fakes online.
5I'm looking to buy a 2023 Volkswagen T-Cross 1.5L Naturally Aspirated, Automatic Comfort model. I want to ask everyone if the current 2023 models on sale have a particulate filter. As far as I know, the 1.4T model does have it, but I'm not sure about the 1.5L. Thank you.
6Does anyone know the size of the air conditioning filter for the 2019 GAC GA6? I've bought many, but they're all a bit thin. I got one from the store before that fit perfectly. This filter is thicker than the usual ones!
7Is the second-hand Outback from the 2020 model the best choice? It doesn't have a particulate filter and it's on the SGP platform. Can someone with experience give some advice?
8Everyone's saying this transmission isn't good. It's said to have common issues. Friends, is this transmission really not durable? I don't drive aggressively, and I'm looking to buy a hatchback or a two-box car. I don't want one with a particulate filter, don't like turbocharged engines, and not a fan of dual-clutch transmissions. Right now, Tiida seems to be the only one without a particulate filter. I'm just concerned about its transmission.
9Does the 2024 Highlander's particulate filter still get clogged? Fellow car enthusiasts, is your particulate filter still getting clogged? I've heard that the materials used now are better, so the chances of clogging are lower. I'm considering just replacing it with an empty shell to avoid future headaches.
10I went to the Toyota 4S store yesterday to check out this car. The exterior and interior are both acceptable. I'm just a bit concerned about one thing: the particulate filter is located in the middle section of the exhaust, which is a bit far from the engine. Theoretically, since it's a naturally aspirated hybrid engine, the operating temperature is lower and the filter is farther from the engine. Wouldn't the particulate filter be more prone to clogging? What do you experts think about this issue?
