عبد العزيز سعود
2024-10-08 17:35
How's the ground clearance of this car? My current ES always scrapes the speed bumps when I drive to the industrial area. Is this one any higher?
سلمان أكرم
سلمان أكرم2024-10-09 20:49
It's almost there, quite low [I want to be alone].
عبدالله حليم
عبدالله حليم2024-10-08 18:54
It seems that the new Crown has a lower chassis, with the official website listing a minimum ground clearance of 130mm.
حسن إياس
حسن إياس2024-10-08 17:45
A little higher?
20
Does your Vitara make any noise when going over speed bumps? I feel like there's some noise coming from the brakes or suspension area in my car.
I have a 2012 Jeep Compass. Recently, when I turn on the AC, there's a clicking sound coming from the glove box area, but it stops after a few clicks. Also, when I'm turning at low speeds, it feels like the rear wheels are stuck, causing the car to vibrate and the rear wheels seem to be rubbing or bouncing on the ground. Has anyone experienced similar issues?
How is the McLaren 720s for daily use? Test drives don't really give the full picture. I've seen on TikTok that McLarens often have minor issues. Can any owners share specific problems? Is the suspension safe for speed bumps and underground garages? I'm planning to get one soon. Does the mileage make a big difference? Currently looking at one with 6,000 km and another with 30,000 km.
Which car has a higher ground clearance compared to the GT? Considering the road conditions are quite challenging. 🤔
Is there anyone who can tell me if the official height of the Vellfire is really 1.945 meters? Our garage has a height of 2 meters, but there's a speed bump that makes the actual clearance only 1.96 meters without considering any bounce. Can anyone confirm if the actual vehicle height is 1.945 meters?
Hey fellow car enthusiasts! I'm currently driving an '09 MDX with a 5-speed and I absolutely love it. I'm thinking about upgrading to a newer model with a 6-speed. Any thoughts on whether it's worth it? If the 6-speed isn't great, I might just refurbish my current one. [Handshake]
Driving over speed bumps at 60 km/h can indeed have an impact on your car. It might cause stress to the suspension system, tires, and potentially the alignment. It's always best to slow down for speed bumps to avoid any potential damage.
After driving the Venza over bumpy roads, there's always a strange noise coming from the trunk, like something is rubbing or hitting against each other. The same noise happens when turning or going over speed bumps. I've removed all the tools from the trunk and taken off the plastic covers, but the noise is still there.
Why does it feel like the ground clearance of the Sunny is quite high? Looking at the Accord, it seems lower than the Sunny. I wonder if it's just a visual thing or if older cars are generally higher than the newer ones.
Toyota Toyota Crown
Toyota CrownAED 199,900 ~ 229,900Hybrid
