محمد تركي
2024-11-13 18:59
Can a rear armrest be installed on the low-end version seats? As mentioned, if the front seat frames of the high-end and low-end versions are the same, you can order a pair of armrests from the manufacturer and install them yourself.
محمد إدريس
محمد إدريس2024-11-13 19:20
That armrest isn't safe; during sudden braking, it's easy to hit your head, especially for kids in the backseat! How many people actually wear seat belts while driving in the city?
محمد تركي
محمد تركي2024-11-13 19:05
Can owners of the base model help ask the 4S shop? As a potential customer, I inquired, and they said it was just launched, so they're not very clear either.
Hello everyone! My brother's about to order a car. He's interested in the LTD with full-time 4WD for driving on highways in wet weather but also likes the Offroad version with rear locker + KDSS. So, I have a few questions: 1) Can the LTD have a rear axle locker installed? How about the ARB air locker, is it a non-destructive modification, and how's the quality? 2) In rainy or snowy weather with the Offroad version, what happens if you drive fast in two-wheel drive? Isn't it unsafe due to slipping? If you switch to H4, does it have a center differential, and what's the maximum speed you can go (80 km/h)? 3) If we end up buying the LTD, can we modify it with the TRD front bumper? The TRD front really looks good. Thanks, everyone!
Hey guys, can the low-end version be fitted with daytime running lights? I want to ask, is there a switch at the left leg position?
I've had the top-end version of the Venucia Star for a year, and I've driven 4800 kilometers. Now I've noticed that when going over those really low speed bumps on highways, the rear end sways, with noticeable lateral movement at the back. (Speed is under 60, and ESP is automatically on.) Do you guys have the same issue?
Hey everyone, I need some help with my Peugeot 206! Thanks a lot in advance! 1: Is the 2007 model with a 1.6L manual engine Euro 2 or Euro 3? 2: How can you tell the difference between the high-end and low-end versions of this car? 3: Why are some interiors white and others black? 4: Why are the instrument panel colors different?
I want to install an armrest. How do I remove the armrest on the driver's seat? Any advice, folks?
Is there a pre-installed loudspeaker wiring harness and plug for the rear doors in the 2017 manual version of the Hyundai Reina? I'm considering adding a pair of speakers and would like to know if it's ready for installation.
I heard that the low-end Elite version doesn't have a car multimedia system. Does anyone know how to solve this? Can it be handled??
If the 95 comes out with a five-seat version and updates its interior, sales would definitely increase. The seven-seater really can't compete with other manufacturers.
Hey everyone, do you ever feel like the armrests on both sides are too low when you're driving? Both my arms end up hanging in the air, and it's really tiring. How do you guys deal with this? Did you buy any accessories? Any recommendations?
Toyota Toyota Crown
Toyota CrownAED 199,900 ~ 229,900Hybrid
