أنيس عبدالرحمن
2021-02-04 11:03
Whose car idles at 1000 RPM when warming up, and has anyone fixed it?
Comments( 10 )
علي ذكي
علي ذكي2024-07-31 06:39
The idling of the 2011 model is currently normal in both winter and summer. It's a good idea to have an experienced Volkswagen mechanic check it out, as both the sensor and idle motor could be potential issues!
محمد مستنصر
محمد مستنصر2024-07-06 07:10
What car?
فهد بلال
فهد بلال2024-07-05 21:18
That's normal for me too.
أنيس عبدالرحمن
أنيس عبدالرحمن2024-07-05 13:47
My car should be at 600 RPM after 20 seconds. If it doesn't come down to 1,000 RPM, there's definitely a problem. If the engine oil is poor and the idling time is long, this issue doesn't occur when the outside temperature is 0 degrees.
أنيس عبدالرحمن
أنيس عبدالرحمن2024-01-02 18:14
Whenever the outside temperature hits zero degrees, my old car's engine idles at over 900 RPM even when it warms up to 90 degrees. But if the temperature is above zero, it drops to 700 RPM just 2.30 seconds after starting. I can't figure out the problem!
علي عمار
علي عمار2021-04-29 21:42
After starting, the engine's RPM drops after 2-3 minutes.
2
سعود فؤاد
سعود فؤاد2021-04-15 09:54
The automatic idle speed is 600 and it remains constant.
فهد طاهر
فهد طاهر2021-02-08 15:44
When I start the car cold, the idle speed is 800 RPM before the first service, and 850 RPM after. After driving for a while, when I stop, it settles between 700-750 RPM. However, the idle speed is adjustable. You might want to check with the 4S shop to see if they can help you with that.
2
محمود محمد
محمود محمد2021-02-04 16:30
You can adjust the idle speed. Just go to the dealership and have them adjust it for you.
علي أنيس
علي أنيس2021-02-04 12:58
When the car is warmed up, an idle speed of 1000 is indeed high. Normally, it should be around 750 to 800. It might be an issue with the idle speed motor.
