When you turn the key, if there's a buzzing sound near the battery and fuse box, what's going on?
When the CX-7's headlights are turned on, there's a buzzing sound, like "zzzz." What could be causing this?
Hey fellow car owners, have you experienced a buzzing sound in your S40 even when it's not started? What's the reason for this?
My radio keeps losing power, could you tell me where the fuse box is?
4The cigarette lighter fuse for the 1819 model of Yuxiang is located in the fuse box. You can usually find the fuse box under the dashboard on the driver's side or in the engine compartment. Please refer to the vehicle's manual for the exact location and diagram of the fuse box.
5Hi, what could be causing the steering wheel to make a buzzing sound when turning?
6Why is there a buzzing sound coming from the fuse box and then the headlights turn on and the wipers work by themselves?
7After turning the key, it doesn't spring back, and there is a squeaking sound when shifting gears. What could be the issue?
8To check the fuse for the front left low beam on a Skoda, you should first refer to your vehicle's owner's manual. The manual typically contains a diagram showing the location of the fuse box and details about each fuse. In most Skoda models, the fuse box is usually located either under the dashboard on the driver's side or in the engine compartment. Once you locate the fuse box, look for the diagram that indicates which fuse corresponds to the low beam lights. Make sure to replace any blown fuse with one of the same amperage.
9When you hear a clunking sound after turning the steering wheel, what's going on?
10What's going on with the knocking sound when slightly turning the steering wheel on the 2021 Jeep Compass?
