The low-pressure pipe is frozen, and the air conditioner isn't blowing cold air. I've already replaced the expansion valve, condenser, compressor, and left servo motor, but it's still not working. Does anyone have a good solution?
Is it normal for a loud humming noise, similar to an air conditioner compressor, to come from the front of the car during charging?
I've got a 2014 Grand Cherokee, and lately when I turn on the heater, the driver's side vent blows cold air while the passenger side vent blows warm air. Does anyone know what might be causing this?
4I've noticed that the two air vents under the main driver's seat in my ASX tend to blow cold air on the left foot. Not sure if other drivers have experienced the same issue. I tried blocking it with tissue paper, and it seems to help a bit. Any other good solutions from fellow drivers?
5What's going on when the heater in a Changan Yuexiang is blowing cold air?
6My 207's automatic air conditioning is having issues. The air only blows towards the windshield and can't be switched to other directions. The display on the panel works, but it doesn't actually change. The AC compressor starts, but it keeps blowing hot air. The temperature adjustment panel shows the settings, but the temperature doesn't change.
7When I use the air conditioning for a longer time in the summer of 2019, the cold air stops blowing inside the car. Does anyone know why?
8What could be the reason that the air conditioning in my 2011 Phaeton blows cold air before hitting the highway, but gets warmer the longer it runs?
9Why does the air conditioning blow cold air while driving, but not when stopped at a traffic light?
10The low-pressure pipe is frozen, and the air conditioner isn't blowing cold air. I've already replaced the expansion valve, condenser, compressor, and left servo motor, but it's still not working. Does anyone have a good solution?
