خالد أصغر
2023-10-08 22:39
My Touran's engine noise has suddenly increased, and it doesn't drive as smoothly as before. Seeking help from the experts.
أنيس عبدالرحمن
أنيس عبدالرحمن2024-01-03 16:26
The engine oil quality is too poor, improve the oil level!
The rear wheels of my Viano are experiencing severe tire wear, and there's a misalignment of 0.9 that can't be corrected with standard alignment. Seeking advice from experts for a solution.
The gear is constantly showing in N position. There's no response when shifting to A or reverse gear. Seeking advice from experts. What might be the issue?
Recently, my fuel consumption has suddenly increased significantly. I suspect it might be the carbon canister purge valve. How should I check it? Can any experts help out?
Where can I find the air vent tabs for the Multivan T5? Seeking help from the experts.
How to distinguish if the Compass is CVT or AT? Checking the VIN shows different results, some show CVT and some show AT. Seeking help from everyone.
How to fix the rattling noise in the trunk of a V93 while driving? Looking for advice from experts.
When driving, if the car suddenly doesn't respond when you press the accelerator, and even flooring it doesn't increase the RPM, but releasing and pressing it again solves the issue, this could be a problem. When starting on a steep slope, if the car feels powerless and sometimes can't climb, requiring several attempts to increase RPM, there might be an issue to address.
I need some advice from experts: I have a 2013 1.4T Touran. Recently, the engine occasionally makes a loud noise after starting, and the idle speed is over 1100. But after turning off and restarting, the engine sounds normal, and the idle speed is around 700, back to normal. What could be the issue?
I recently got a 2013 1.4T VW Touran with 110,000 km on it. It's been owned by one person before me. Currently, the big electric fan isn't working, but the small one still is, and the water temperature isn't high. I'm planning to replace it in a few days. The only issue right now is a whistling noise in 5th gear at 70-80 km/h. It doesn't happen in 4th gear, only in 5th when I accelerate, and it stops when I release the gas. 🙂‍?️ Seeking advice from experts—is this a transmission problem?
