عمر سعود
2023-04-01 00:09
My 2011 VW Touran shakes a lot when refueling. Any advice?
خالد مسعود
خالد مسعود2023-07-10 21:10
Take the car to the workshop and have the technician check the spark plugs. Use the computer to scan the data stream and inspect the intake and fuel systems. If there are no fault codes from the computer diagnostics, just proceed with regular cleaning and maintenance, prioritizing the cleaning of the fuel system.
سعود رياض
سعود رياض2023-04-04 23:02
Check if the engine mounts and the transmission bracket need to be replaced.
حسن صلاح الدين
حسن صلاح الدين2023-04-04 00:01
Got a new car [small applause]
علي ذكي
علي ذكي2023-04-03 20:59
Check for cylinder misfire.
أنيس عبدالرحمن
أنيس عبدالرحمن2023-04-02 15:08
Check if there's an issue with the ignition system! If the engine has a problem, just connect it to a computer and it will show up!
When the Volvo S80 shakes during refueling, consider the following potential causes:
Hey everyone, can someone help me out? The loudspeaker on the driver's side of my 2011 S40 is very low. Any advice?
Help! When driving on slightly rough roads, the gear shift shakes a lot. Is there any way to fix it? I'm willing to offer a reward for anyone who can solve this problem!
Does your steering wheel shake a lot when you brake at speeds over 60? Have any of you experienced this phenomenon?
For the 2011 VW Touran with a manual transmission, it's generally recommended to use high-quality engine oil that meets the manufacturer's specifications. A popular choice is synthetic engine oil from brands like Castrol, Mobil 1, or Shell. Always ensure the oil meets the VW 502.00 specification for optimal performance.
When the air conditioning is on and blowing cold, the car shakes a lot, especially when stopped at a red light. It's uncomfortable. Do any of you have this issue with your car?
My Hongqi H7 is lacking power when refueling, and it shakes and sputters. The dashboard indicates an exhaust system issue.
My Pang Ge has suddenly started to shake at idle these past two days. Went to the 4S shop and changed the high-pressure fuel pump, checked other areas too. It doesn't shake when driving, doesn't shake when braking with gear engaged, but shakes when in neutral. It shakes as if I'm braking. Can any experts help me figure this out?
My 2015 manual classic model is shaking a lot when I drive it, and the sound is like it's gasping for air. The power also seems to be lacking. What's going on?
