I want to ask the experts, why does the air conditioning not work when I turn on the internal circulation? The light comes on briefly and then goes off, but the heating works fine. Why is that?
The heated rearview mirror isn't working, but the electric adjustment is fine. I've been to several repair shops, and they all say I need to replace the base, which costs over 2000 for an original one. Any experts here who can give some advice? Thanks!
It's a common issue. The big smell in your car during summer is usually due to the heat causing materials inside to release odors. When you turn on the air conditioning, it helps circulate air and reduce the smell.
Why is this Bluetooth always showing in black and not working? Other functions are fine.
4The air conditioning internal circulation of the 2016 Hongqi H7 with the chrysanthemum logo is broken. How can it be repaired? Is it that one of the shafts of the air conditioning flap is broken? Do I have to replace the entire air conditioning assembly?
5Hi everyone, I've got an '07 model practice car. When I turn on the internal circulation switch, the light comes on, but there's no circulation effect. What's going on?
6If the external circulation of your car's air conditioning system can't switch to internal circulation, it might be due to a problem with the actuator or a control switch. The cost for repair can vary depending on the make and model of the car and the specific issue. I recommend consulting a local mechanic for an accurate diagnosis and cost estimate.
7The reverse camera frequently goes black, and sometimes it works. How can I fix this? Looking for advice from the experts. 🙏
8Is everyone's air conditioning vent working fine? I feel like there's not much airflow to my feet...
9I want to ask the experts, why does the air conditioning not work when I turn on the internal circulation? The light comes on briefly and then goes off, but the heating works fine. Why is that?
10Why isn't the smart air conditioning on the Hongqi Zhilian app working?
