سلمان سالم
2024-07-19 15:28
I recently got a 2013 1.4T VW Touran with 110,000 km on it. It's been owned by one person before me. Currently, the big electric fan isn't working, but the small one still is, and the water temperature isn't high. I'm planning to replace it in a few days. The only issue right now is a whistling noise in 5th gear at 70-80 km/h. It doesn't happen in 4th gear, only in 5th when I accelerate, and it stops when I release the gas. 🙂‍?️ Seeking advice from experts—is this a transmission problem?
Comments( 7 )
علي ذكي
علي ذكي2024-08-08 12:05
The Touran's electronic fan seems to still have two controllers and two motors. If one fan stops working, it can cause a lot of noise and vibration!
حسن حمزة
حسن حمزة2024-08-06 14:15
Which light turned on?
عبدالرحمن أبشير
عبدالرحمن أبشير2024-08-06 05:24
You can go to a 4S shop or a larger repair shop for an inspection.
سلمان سالم
سلمان سالم2024-07-19 21:00
Crying 😭
سلمان سالم
سلمان سالم2024-07-19 19:34
There are no experts here. 😊
سلمان سالم
سلمان سالم2024-07-19 16:24
Seeking a pro!
سلمان سالم
سلمان سالم2024-07-19 15:37
Looking for a pro [applause]
When driving at speeds between 50 to 70 km/h, should I use fourth gear or fifth gear? I've just got my license.
2008 Yaris 1.6 automatic, driven 130,000 km. Now, when the engine is cold, it can't shift from 3rd to 4th gear, and it can't accelerate beyond 70 km/h.
I bought a 2009 Yaris RS 1.6 automatic for 30,000 RMB with 110,000 km on it. The exterior and interior are in good condition. Is it expensive?
Hey car enthusiasts, how do you guys shift gears with a 1.3L manual? 2nd gear at 20-40, 3rd at 40-60, 4th at 60-80, and 5th above 80!
Hi everyone, when I'm accelerating with my FJ and shifting gears, I notice that the shift from 4th to 5th gear feels more pronounced and abrupt. Is this normal? There are no error codes. It's not noticeable during normal driving, but if I deliberately pay attention to each gear shift, I can feel a slight jolt from 4th to 5th. To notice this, I have to keep the throttle steady without releasing or pressing it more. During the 4th to 5th shift, there's a noticeable abrupt feeling. However, if I ease off the throttle during the 4th to 5th shift, there's no issue at all. Any thoughts or suggestions are welcome. Thanks!
Does the S gear shift up and down? Why can it only be in 1st gear and not in 2nd, 3rd, or 4th gear?
When merging onto the highway with a CX-30 MT, which gear do you use to accelerate? From 50-80 km/h, there's not much power in 4th to 6th gear. Do you need to rev it up to 100 in 3rd gear?
I have a 2021 model Santana. When I'm driving between 50 to 60 km/h, the gear is in 5th, but the display shows 2nd or 3rd gear. However, the 2nd and 3rd gears seem to be neutral. What's going on?
Why has there been frequent gear lag recently? It's a 2019 model with a 1.4T dry dual-clutch. After picking up speed and then braking, the gear doesn't match the speed. For instance, it's in 6th gear at 45 km/h and 5th gear at 35 km/h, but it doesn't downshift further. It upshifts quite eagerly. Went to the 4S shop, and they said the engine isn't strong enough, and the gearbox can't be adjusted?
