سلمان له
2024-05-14 18:49
I need some advice from experts: I have a 2013 1.4T Touran. Recently, the engine occasionally makes a loud noise after starting, and the idle speed is over 1100. But after turning off and restarting, the engine sounds normal, and the idle speed is around 700, back to normal. What could be the issue?
محمد محمود
محمد محمود2024-05-19 21:24
No big impact. Parked overnight and the car started like this in the morning.
Is anyone familiar with solving the issue of idle speed occasionally rising to 2000 RPM and then dropping back down on a stock MG HS? It's particularly noticeable at low speeds.
Is it normal for the idle speed of a 2015 Volkswagen Touran to rise to 900 RPM when the outside temperature is below 0 degrees while the engine is warm?
When driving at low speeds over rough roads or speed bumps, and then accelerating, the RPM between 1100 to 1500 feels like it's cutting out. Once the throttle picks up, everything returns to normal.
Why is the idle speed around 600 to 700 RPM?
Does anyone with a 2008 model experience the same issue? In the hot summer, whether idling or driving, the blower occasionally runs at a high horsepower, making a loud noise. It's more noticeable when idling and parked.
Hey everyone, what’s the fuel consumption of your Alto automatic? I feel mine is too high, 24.5 liters only covers about 300 km. The light came on at 287 km. Also, my idle speed when starting cold is around 1500, but it goes back to 1100 once the engine warms up. Is this normal for fuel consumption and idle speed?
The Volvo C30 2.0D has a normal idle speed of 850±20 RPM when in gear, but the idle speed is high at 950±20 RPM when in neutral. What's going on?
Is it normal for the fan to frequently turn on, with a particularly loud noise, and then stop after a while, even when the water temperature is normal? Has anyone experienced this? It also happens when idling, where it turns on once every few minutes.
After refueling my Jetta VS7 at the gas station, the idle speed tends to be high, around 1000 RPM. Then, during driving, the speed fluctuates. After driving for about ten kilometers, the idle speed returns to normal. Alternatively, if I turn off the engine and restart it, the idle speed also normalizes. I've tested this each time I refuel, and it's always the same situation.
