حسن عوض
2023-12-05 22:55
I have a basic manual version of the 2011 Touran. The center console only has a radio, and I've been using a Bluetooth adapter through the cigarette lighter to listen to music, but there's often electrical interference noise. I've tried switching 2-3 adapters, but the issue persists. Does anyone have good suggestions? I feel like Android screens priced between 300-500 might not be reliable, and I don't want to spend over 1000 on modifications. How can I use the original car audio system?
عمر لاويل
عمر لاويل2023-12-14 23:56
There is a USB-powered Bluetooth device with an AUX port, which can be directly replaced. Baseus sells it.
I've driven 80,000 kilometers. Do I need to change the transmission oil? Which brand of oil should I use?
I've had my car for four and a half years and it's only done 36,000 km. It's a 2019 model with the 4J11 engine. Recently, when I start it cold, the engine struggles a lot. The RPM doesn't go up immediately, and the needle wobbles between 500 and 1000 for a few seconds, making it feel like it's about to stall. Then the RPM suddenly jumps to 2000-3000 before settling back to normal idle after a few seconds. There are no warning lights, and once it's running, everything seems normal. I've cleaned the carbon buildup and throttle, and checked the intake for leaks, but the issue persists. I'm not sure what to check next. What should I look into?
Can I use a USB drive to listen to music?
If you're looking for an off-road vehicle and considering the Tank 500, Tank 300, a used Land Cruiser, or a Patrol, it can be tough to decide. Prioritizing durability is a good start.
Just got the car 2 days ago. When I picked it up, it showed 435, but it seems like I've only driven less than 300, with a bit over 90 left, so I went to charge it. Is this normal for city driving?
Do any of you use a USB drive to listen to music? Does the USB drive need to meet certain requirements? Why can't the songs I downloaded on my previous USB drive play? I used a card reader with a memory card, and it worked before, but now it always switches back to the radio interface.
I'm considering buying a used advanced version mainly for city commuting, but it will spend a lot of time in the parking lot. Since I've been living abroad for a long time, I'm not sure if I should buy a car. I think this car looks pretty good. Currently, the available used advanced versions are only in white and orange. Which color looks better? I want to make a decision remotely first, otherwise, I might not have options when I return home. Thanks, everyone.
Hi everyone, I have a question about my 2016 Nissan Sunny. Sometimes the car won't start on the first try, but if I turn the key off and try again, it starts. This happens every time I start the car. I've had the battery checked and it's fine, and I've also had the starter cleaned and maintained, but the problem persists. Does anyone know what could be causing this issue?
How do I connect CarLife on the GAC GS5's infotainment system? I've downloaded it, but I can't connect. I'm using an Android phone. Can someone who knows help me out? Thanks.
