I have a 2009 Touran 2.0 manual, and I'm having trouble shifting into first and reverse. Is anyone else experiencing this? Also, when I release the clutch in first gear, the engine shakes like it's about to stall. It also shakes a bit during rapid acceleration. Is this normal?
Is it normal for the clutch of a 2009 Accent to have some play at the beginning when you press it?
I want to ask fellow car enthusiasts, for those with dual-clutch transmissions, does your engine shake like a manual car about to stall when you're in a traffic jam?
I'm looking to install a roof rack on my 2009 manual Touran 2.0, which doesn't have one. Does anyone with the same model have experience to share? 😊
4I have a 2009 Accent. Why does the car stall every time I press the clutch?
5I have a 2009 Touran 2.0 manual, and I'm having trouble shifting into first and reverse. Is anyone else experiencing this? Also, when I release the clutch in first gear, the engine shakes like it's about to stall. It also shakes a bit during rapid acceleration. Is this normal?
6Why does the start-stop function in the 2009 Smart cause the vehicle to stall? It usually happens when waiting at a red light. When the start-stop function is on and the light turns green, I find that the vehicle has already stalled, and I have to wait a moment before I can restart the vehicle.
7The clutch in the 2013 Touran manual feels heavy, and the car body shakes slightly with a small release.
8Hey car enthusiasts! I've got a 2018 Santana with 50,000 km on it. In winter, I'm having trouble getting it into reverse—it just goes into first gear when I push up. But if I let it idle for 10-30 minutes, I can get it into reverse. What's going on?
9I have a 2012 Subaru Outback with an EJ25 engine, almost 200,000 kilometers. It has noticeable shaking at idle and stalls during sudden braking, especially when the engine is cold. I cleaned the throttle body carbon build-up recently, which improved it a bit but didn’t completely solve the problem. The engine is quite loud during hard acceleration, and I’m not sure if it’s the engine or the transmission. Also, recently it shakes at speeds over 100 km/h. Anyone experiencing the same issues?
10Can the 2015 2.0 Ultimate 508 be set to have the "adaptive rearview mirror during reverse" function? I've tried following the manual a couple of times without success. Does this version not have this feature?
