I have a 2007 Touran, automatic 1.8t. It jerks noticeably during acceleration. When idling while parked, the RPM intermittently drops by 100-200, and the car lights dim. What should I do? (I've previously cleaned the fuel injectors and throttle body.)
I've got a 2012 Changhe Liana, and it's been having issues with shaking at idle, while driving, and even more when the AC is on. I've already replaced the spark plugs and ignition coils, and cleaned the fuel injectors and throttle body, but the problem persists. The check engine light comes on frequently. Does anyone know what might be causing this issue?
DIY Cleaning of Toyota Verso Throttle Body
4Do I need to perform adaptation after cleaning the throttle body?
5Hello fellow car enthusiasts, have any of you cleaned the throttle body before? I've heard that cleaning the throttle body on an MG3 is quite a hassle, taking up to 5 hours and costing 500 bucks.
6The 2008 Volkswagen Touran 1.8T shows a fuel consumption of 11 liters on the highway. After changing the fuel injectors and spark plugs, there's still no improvement. What could be the reason?
7Hey guys, how do you clean the throttle body on your MG3?
8After cleaning the throttle body yourself, the engine warning light came on. It doesn't affect driving, but how can you resolve this?
9Hello car enthusiasts, does the 2021 Jeep Compass 1.3T need a throttle body cleaning?
10In the morning, when starting the vehicle and driving at low speeds, it occasionally stalls. I've already cleaned the throttle and injectors, but it still stalls sometimes. If the speed picks up, it doesn't stall. What could be the reason? 🤦♂️
