علي باسم
2023-09-20 14:54
Hi everyone, I need some advice. I have a 2015 1.4T Touran with nearly 110,000 KM on it. Recently, in the past six months, I've noticed that when making U-turns or reversing into parking spots, there's a sudden large resistance when turning the steering wheel. This doesn't happen during normal driving, only when suddenly turning the steering wheel. Can someone help me figure this out? Thanks!
فهد شعبان
فهد شعبان2023-09-24 11:00
It's recommended to check the rods, ball joints, and steering gear on the chassis.
عبد الناصر عبدالرحمن
عبد الناصر عبدالرحمن2023-09-22 11:24
What's the fuel consumption? What type of fuel do you use, 90-something? Is it automatic transmission?
20
نايف صلاح
نايف صلاح2023-09-21 08:41
Electric power steering (EPS)
عبدالله سليم
عبدالله سليم2023-09-20 15:18
Check if the steering gear is leaking oil.
What could cause the steering wheel to shake during sudden acceleration? Today, when I suddenly accelerated, the steering wheel shook a lot, and I'm not sure what's going on.
The steering wheel is really sensitive... There's no resistance when you turn it slightly left or right, it's like steering an air wheel [facepalm]. You only feel resistance after that gap! You really have to hold it with both hands when driving on the highway!! [facepalm][facepalm] Do you guys experience this too?!!
Hi, what could be causing the steering wheel to make a buzzing sound when turning?
Is it normal for my steering wheel to make a rustling sound when I turn it more than one full circle during a U-turn or while reversing? I just got my Seetus Luxury Edition 20 days ago.
When you hear a clunking sound after turning the steering wheel, what's going on?
Volkswagen Jetta 13 manual fashion 1.6 has a noise when turning the steering wheel. There is no sound when the steering is turned in place, but when driving and turning the steering wheel to the limit, it makes a noise. What could be the reason?
When turning the steering wheel of the MG HS, there's a clicking sound on the left side.
What causes the steering wheel to make a noise when turning the shaft?
