فهد رائد
2024-02-25 09:30
Hi everyone, any idea why my '09 Touran sometimes doesn't idle after starting in the morning?
سلمان خليف
سلمان خليف2024-03-29 12:03
My engine stalled right after starting, and it turned out that one of the ignition coils was faulty. After replacing it, everything was fine. You should check yours.
نايف رحمن
نايف رحمن2024-02-26 10:58
When it's too cold, there indeed might be no high idle speed, but when it's not cold, there is.
Hey folks! Anyone else experiencing this with their Yizhi? What's the issue with the idle speed fluctuating when starting a cold car? Sometimes it hits 2000 RPM right after starting.
The check engine light is on, indicating an engine emission fault, but the DPF regeneration indicator is not lit. Holding the regeneration button doesn't work, and sometimes the vehicle doesn't accelerate properly. What could be the reason for this? Any ideas, everyone?
Hi everyone, I need some advice. The central locking system on my 2018 Dongfeng Renault 2.0 Koleos is acting up. Sometimes it works, sometimes it doesn't. What could be the problem?
Hi everyone, after disassembling and reassembling the intake pipe, the idle is shaking, any idea why? It's an LC100, 4700. I disassembled the intake pipe when replacing the silicone oil fan coupler, and after assembling it, the idle has been shaking. Could it be sabotage?
Hey everyone, I've got an issue with my 09 model. Sometimes while driving, there's a sharp "dang dang" sound coming from underneath the car. It comes and goes, and sometimes I can even hear it when idling. The repair shop mentioned it might be the exhaust pipe but then said it doesn't seem like it. They think it might be coming from the bottom of the engine. Have any of you experienced something similar?
The start-stop switch sometimes works, sometimes doesn't.
In the morning, when starting the vehicle and driving at low speeds, it occasionally stalls. I've already cleaned the throttle and injectors, but it still stalls sometimes. If the speed picks up, it doesn't stall. What could be the reason? 🤦‍♂️
Why does the Outlander have high RPMs when starting in the morning?
Hi friends, what is the idle RPM for your GAC Emkoo after starting the engine?
