حسين عبد الحكيم
2024-01-29 07:30
Hello fellow car enthusiasts, I'm interested in a 2013 Touran with an EA111 engine. Does this engine consume oil? Does it have a lot of minor issues?
Comments( 7 )
أنيس عبدالرحمن
أنيس عبدالرحمن2024-02-16 12:35
Using cheap fake oil often leads to increased noise, higher fuel consumption, and a higher failure rate. In the end, you'll spend more on repairs than what you saved on the oil!
أحمد نوح
أحمد نوح2024-02-03 19:50
Don't buy automatic models before the 2015 version, that transmission is guaranteed to fail.
تركي حسن
تركي حسن2024-02-03 18:09
I also drive the 2013 manual model with the EA211 engine. It has reached 200,000 kilometers, and I've done all maintenance at the 4S shop. There's no oil burning issue so far. I've replaced the clutch once, and there's an automatic opening issue with the sunroof, but no other problems. It's a good car! [Thumbs up]
عبد العزيز عماد
عبد العزيز عماد2024-01-31 23:55
I'm a mechanic. Normally, there aren't many issues with the engine; it's mainly the transmission.
عبدالله سليم
عبدالله سليم2024-01-31 07:35
Generally doesn't burn.
عمر صباح
عمر صباح2024-01-30 17:00
My 2011 model doesn't burn oil. I've always used Mobil 1 and just stick to regular maintenance and part replacements.
حسن ابراهيم
حسن ابراهيم2024-01-29 21:54
Check the car's condition! If the previous owner didn't take care of it, it'll burn!
